How do you turn wireless off?
- Re: How do you turn wireless off?
02-06-2009 9:28 PM
My next door neighbour tells me that if I’m not using the wireless part of my modem/router, I should disable it or switch it off. Can any tell me how to do that? I’m using the Speedtouch 585 v7.0.
Jessica
Jessica
Message 1 of 8
(1,724 Views)
7 REPLIES 7
02-06-2009 9:39 PM
go here http://192.168.1.254/cgi/b/intfs/?be=0&l0=3&l1=1 click the WLAN, then configure at the top, top item, remove the click i.e. dont enable
Message 2 of 8
(812 Views)
02-06-2009 10:06 PM
Unscrewing the aerial generally works as well if you're not confident about changing configurations.
Message 3 of 8
(812 Views)
02-06-2009 10:09 PM
it only one click enable or not, thats easier than removing the antenna
Message 4 of 8
(812 Views)
02-06-2009 10:13 PM
Some of the Thomson's have non-removable aerials too, I think.
Message 5 of 8
(812 Views)
02-06-2009 10:15 PM
Quote from: pierre_pierre go here http://192.168.1.254/cgi/b/intfs/?be=0&l0=3&l1=1 click the WLAN, then configure at the top, top item, remove the click i.e. dont enable
Here's where you need to look.
Message 6 of 8
(812 Views)
03-06-2009 12:14 AM
Thanks Guys,
I just disabled it. Pointless having it on if I don't use it.
Cheers,
Jessica
Cheers,
Jessica
Message 7 of 8
(812 Views)
03-06-2009 9:53 AM
Safer too
Message 8 of 8
(812 Views)
