How do i know if my line is Interleaved?
- How do i know if my line is Interleaved?
09-08-2011 4:59 PM
Hello
What do i look for in my stats to see if its interleaved or not, i have heard people have an option to turn it on or off , i don't have this
cheers peeps
lee
cheers peeps
lee
Message 1 of 3
(1,046 Views)
2 REPLIES 2
Re: How do i know if my line is Interleaved?
09-08-2011 5:18 PM
In most routers if your line is Interleaved then in the DSL connection statistics it will generally say "Interleaved" or "Interleave Path" or words to that effect. Interleaving off however usually appears as "Fast" or "Fast Path". The message displayed is dependant totally on your router. Some routers don't show it at all.
I tested your line and can see that Interleaving is currently disabled.
Hope this helps.
Hope this helps.
Message 2 of 3
(513 Views)
09-08-2011 5:38 PM
Ah i see
Thanks alot Alex
Thanks alot Alex
Message 3 of 3
(513 Views)
