How do I view my tickets?
- Re: How do I view my tickets?
30-09-2014 4:54 PM
I called support and logged a ticket about my intermittently failing connection, but how can I see the status of it?
The member centre is not very intuitive, can someone guide me as to where I can see the status of a ticket so I can add further comments?
Message 1 of 5
(2,416 Views)
4 REPLIES 4
30-09-2014 5:07 PM
Have a look here https://www.plus.net/wizard/?p=search
Message 2 of 5
(2,162 Views)
30-09-2014 6:42 PM
I went to that section before.
Where to go from there?
Message 3 of 5
(2,162 Views)
30-09-2014 7:08 PM
Are you aware that questions and tickets are the same thing? Just check for open questions.
Message 4 of 5
(2,162 Views)
01-10-2014 9:56 AM
Hi sukeshn,
You should be able to select the viewing options at the link that Strat provided. Once you've logged in you should then see a drop down list which gives the options for viewing.
Message 5 of 5
(2,162 Views)
