How do I find my FTTC sync speed?
- How do I find my FTTC sync speed?
19-09-2012 7:03 AM
Had FTTC installed yesterday and was wondering how I find my sync speed?
Had a good connection yesterday, downloading at about 33mb across a range of different speedtesters, but trying again this morning its only downloading between 5mb and 14mb depending on which speedtester I use. Upload speed has remained as it was yesterday though.
Would be good to know what my actual sync speed is, and why such a big drop overnight. (it did resync at about 8pm ish last night).
Message 1 of 8
(5,066 Views)
7 REPLIES 7
Re: How do I find my FTTC sync speed?
19-09-2012 7:26 AM
I don't think you can interrogate the modem directly, without hacking it, to find your synch speed.
Best bet is to try the bt speedtested at http://speedtester.bt.com/
Message 2 of 8
(1,736 Views)
19-09-2012 7:31 AM
Thanks, that's what I thought. Don't really want to start messing with the modem with it only being a day old
BT Speedtester gives me a download speed of 16mb, on a 12-33mb profile. Bit bemused as to why it has halved in speed overnight though.
Message 3 of 8
(1,736 Views)
19-09-2012 10:38 AM
Are you using a wired or wireless connection? If wireless, then I'd try wired to make sure it's not the wi-fi link causing the bottleneck.
Message 4 of 8
(1,736 Views)
19-09-2012 10:50 AM
It is a wired connection. I did try rebooting the modem but it still downloads at the same slower rate. Not overly concerned at the moment, but obviously would rather have yesterdays 33mb than todays speed.
Message 5 of 8
(1,736 Views)
19-09-2012 11:52 AM
Your profile and sync speed are currently showing at 33MB/s, nothing has changed since last night on your line.
Are they still the same? It may be worth trying a PPPoE connection on your PC.
You would need to bypass the Technicolor router and connect via ethernet to the Openreach modem.
Windows
Go to the Control Panel then Network Connections
Click Create a new connection
Choose Connect to the Internet
Select Set up my Connection Manually
Select Connect using a broadband connection that requires a username and password (PPPoE)
Enter the ISP Name: Plusnet
Enter the Broadband Username and Password
Click Finish and click Connect
Let me know how you get on.
Windows
Message 6 of 8
(1,736 Views)
20-09-2012 6:53 AM
Thanks Chris. I tried that but kept getting errors when trying to connect, but I might have done something wrong. I just connected my pc directly to the modem instead of the router and followed the instructions.
However, I have tried the BT speedtester again this morning, and it appears that its back at its 30+ mb download speed. Could yesterdays speeds be related to the training period? The Openreach engineer did say the speeds would go up and down for a few days, but I just didnt expect it to be such a big difference.
Cheers!
Cheers!
Message 7 of 8
(1,736 Views)
20-09-2012 12:14 PM
They will fluctuate in the first few days, and the amount will vary on each individual line.
I would suggest connecting back into the router and see if your speeds are different.
Message 8 of 8
(1,736 Views)
