How do I change my MTU on my plusnet router?
- Re: How do I change my MTU on my plusnet router?
- « Previous
- Next »
31-01-2013 5:08 PM
Would I be right in thinking that includes broadband throughput speed?
Quote from: jelv
Quote from: SuperSaiyan4 I want it set to the Xbox Live recommend setting of 1364
Why would you want to slow your connection down when used by anything other than the Xbox?
31-01-2013 5:10 PM
Well having read a bit more about MTU for this day and age looks like it will slow down data transmission however done speed tests found no reduction.
Anyways it was set on 1492 and instead ive bumped it up to 1500 so lets see how that goes.
Thanks all for the help, much appreciated.
31-01-2013 5:22 PM
If the Xbox is set to use 1364, as long as the router is set to that or higher the Xbox will happily use 1364. That applies to all devices they will use their setting or the router whichever is the higher. So setting the router to the maximum possible makes sense as it should allow optimum performance of all connected devices.
31-01-2013 5:24 PM
31-01-2013 5:27 PM
If you want the best possible gaming times, its always going to be best to hook up with an Ethernet cable rather than using wireless. As EJS states, there's very little information about the maximum capabilities of the XBOX's internal adapter. I would also guess that the max is only 65Mbps.
Also, the Thomson/Technicolor boxes that Plusnet ships are amazing at keeping a connection live with a low signal to noise margin. I've used a Thomson 585 for four years and when it dies, I'll probably get another.
31-01-2013 5:32 PM
31-01-2013 5:37 PM
When I had a 587, mine was permanently stuck on 54 thanks to my phone being b/g. Now I'm using a 585 that doesn't matter anymore.
31-01-2013 5:41 PM
Ive been changing my MTU (Internet) using Telnet and noticed its default is 1492, if I increase it to 1500 which it says is the apparent default setting some internet pages like gaming sites become unstable in the sense that images are missing, also if I try doing a speedtest it hangs and becomes erratic. So ive put it back to 1492, strange.
31-01-2013 5:42 PM
Sorry I got ratty earlier. I've since read your previous posts and accept you have reason to be generally worked up. I still feel objecting to Oldjim's post was unwarranted though.
Quote from: SuperSaiyan4 Not sure just trying to set the MTU for my console, I don't remember that impacting my internet speed back in the day but I am guessing things have now changed? If I lower my MTU will my internet speed get reduced also?
Re the internet speed, I would have thought changing the router down below the 1500 (1492 effective) would mess with that, but I'm not sure. Which is why I asked jelv - or anybody. It's not my area of expertise. I'm not too happy about the upload side with it set to 1500 either.
31-01-2013 5:49 PM
If it's of any interest, my Buffalo router page for setting the MTU has its default 1500, but I use the auto-setup wizard, (similar to what the PN one does). Looking at the Diagnostics page which shows the live values of everything, that has 1454.
Quote from: SuperSaiyan4 Ive been changing my MTU (Internet) using Telnet and noticed its default is 1492, if I increase it to 1500 which it says is the apparent default setting some internet pages like gaming sites become unstable in the sense that images are missing, also if I try doing a speedtest it hangs and becomes erratic. So ive put it back to 1492, strange.
31-01-2013 5:49 PM
Also having just come off from black ops 2 which destroys any sense a person can have I took out some of my frustration on here which I am very very sorry for 😞
In regards to the MTU thing again yes it makes no sense, 1500 is the default however for Internet it is set to 1492, if I raise it to 1500 websites don't fuction correctly and nor does speedtest.net which is weird.
Anyways im done tinkering with it now lol am gonna go watch ParaNorman on the Xbox 360 in 1080p lol.
31-01-2013 5:50 PM
Quote from: SuperSaiyan4 some internet pages like gaming sites become unstable
If the packets cannot be handled at the server than they will either be rejected or fragmented and result in what you described. I'd recommend 1478 or 1492 if Plusnet still uses PPPoA connections.
- « Previous
- Next »
