How do I access the VPN from my home?
- Re: How do I access the VPN from my home?
25-05-2010 3:56 PM
I am attempting to work from home on a once off basis and am on a home value package. I understand that I can do port forwarding to include my VPN address to enable me to access my work emails and system. Does anyone know how I can do this?
Thanks,
Sarah
Thanks,
Sarah
Message 1 of 3
(907 Views)
2 REPLIES 2
25-05-2010 4:21 PM
There should be no need to setup port forwarding. You need to setup a VPN connection. to do this go to the Control Panel select Network and Sharing and you should find a VPN option.
Message 2 of 3
(331 Views)
25-05-2010 5:55 PM
as itsme says once you've made the VPN connection it should just work.
However if you are using the PlusNet supplied Thomson TG585V7 router and using a PPTP VPN connection ( the normal with the Microsoft VPN client ) then you MAY need to upgrade the router firmware for it to work. See here http://community.plus.net/library/hardware/how-to-upgradedowngrade-the-firmware-on-the-thomson-585v7...
Message 3 of 3
(331 Views)
