How To Change DNS Settings On The Fibre Router?
- Re: How To Change DNS Settings On The Fibre Router...
16-05-2013 9:46 AM
Does anyone please know hot to change the DNS settings on the Plusnet Technicolor fibre router?
Re: How To Change DNS Settings On The Fibre Router?
16-05-2013 9:52 AM
16-05-2013 12:34 PM
16-05-2013 1:03 PM
16-05-2013 1:21 PM
You need to add the extra ones with a higher metric
16-05-2013 1:26 PM
You're probably correct - it's over 2 years since I had to telnet into my old 585V8.
16-05-2013 1:31 PM
16-05-2013 2:19 PM
Quote from: w23 Are you still connected while trying to remove existing (in-use) entries?
Yes, I have been. Hmmm, I wonder if connectivity locks them. It would make sense I suppose.
Edit: But having said that I have to be connected in order to remove them.
16-05-2013 2:27 PM
16-05-2013 2:38 PM
Yes, the router was connected to the internet.
I've added the two DNS entries that I wanted all OK and that seems to be working fine with the metric priority set as 2. So as it stands things are now sorted thanks very much to your link and info.
The Plusnet router replaces my identical o2 one, but I have to say that although the o2 one followed a similar Telnet process it was a lot easier to apply.
dick:quote
16-05-2013 2:49 PM
16-05-2013 11:43 PM
17-05-2013 1:17 PM
The following shows two methods to change the DNS resolver in the router.
http://npr.me.uk/changedns.html
