House move question
- House move question
- « Previous
- Next »
Re: House move question
19-06-2009 1:03 PM
Connection Speed 2208 kbps 448 kbps
Line Attenuation 59.0 db 31.5 db
Noise Margin 9.8 db 18.0 db
These are the stats that I've got with everything plugged in with the router in the master socket but not the test socket.
Oldjim, I haven't got access to the internet on my computer at the moment (using hubby's) so can't upload a photo from my camera. Is there something specific you want me to look for?
19-06-2009 1:10 PM
There should be wires connected to slots 2 and 5 but there may be one or two others
19-06-2009 1:11 PM
Three snags with this setup
1) I've got no phones
2) My computer is offline
3) The mains lead for the router is sprawled across the hall
could be a tad inconvenient
19-06-2009 1:23 PM
19-06-2009 1:24 PM
I've looked at the socket and I see an orange and a blue connected and a green and brown which isn't connected to anything. I've taken a photo with my mobile phone but can't seem to connect this up to the computer. Is there some way of sending this through by sms?
19-06-2009 1:30 PM
Can you check the other sockets in the house to see if only the same two wires are connected
I can't help on SMS as I have a mobile phone which only does texts and calls non of this fancy rubbish
19-06-2009 2:11 PM
I've now altered things slightly with regard to what's plugged into what and where I put my filters.
As you'll see from the image, the speed is down from when the router was in the master socket and nothing else was plugged in. I've moved my router back upstairs and the speed is better than what it was before I went crawling around the house on my hands and knees ;D. Incidentally, with the new 'wiring' (I use that term very loosly) and the router still in the master, speeds were much the same as this. It's as if everything drops when there's anything else on the line. Is this normal behaviour?
I think I'll need to monitor the stats and see if they remain consistent. I'm still in the 10 day trial thing so I don't know if it will stabilize at the right level after all these experiments.
Perhaps I'll get someone to take a look at the wiring and see if anything can be done to improve things. We've just had the whole house redecorated so don't want to have to lift carpets and floorboards, etc.
19-06-2009 2:37 PM
This is a good piece on internal wiring. Have a look through it, it describes how to remove the unnecessary orange bell wire and simplify the wiring.
http://www.jarviser.co.uk/jarviser/bellwirenutshell.html
I went through this process last year and made huge improvements in speed and stabilty
19-06-2009 4:00 PM
Thanks for the link. I think my socket is slightly different so I'm not sure what to do. I've attached a photo.
I've run a few further tests. I'm a bit confused. The router and BT Speed Checker say my downstream is 2304 kbps. I don't understand how this relates to the IP profile. I thought that was the maximum I could get but, if so, that doesn't make sense. The Exchange checked seems to think I can get 1.5 Mbps and http://www.mybroadbandspeed.co.uk says my downstream is only 853 kbps. Looking at this, what is my speed?
BT Speed Checker - http://speedtester.bt.com
Test1 comprises of Best Effort Test: -provides background information.
Your DSL connection rate: 2304 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
IP profile for your line is - 750 kbps
Actual IP throughput achieved during the test was - 642 kbps
Broadband Line Checker - http://www.productsandservices.bt.com/consumerProducts/displayTopic.do?topicId=16738
For Postcode ****** on Exchange CROWNHILL
We've just tested your line and can confirm your line supports the UK's most complete broadband package, BT Total Broadband. We estimate your maximum connection speed to be up to 1.5 Mbps (Megabits per second).
Date Download Speed Upload Speed
Today 15:52 853 kbps (107kB/s) 382 kbps (47.8kB/s)
Router Stats
ADSL Link Downstream Upstream
Connection Speed 2304 kbps 448 kbps
Noise Margin 9.1 db 18.0 db
19-06-2009 4:30 PM
Connection Speed 1280 kbps 448 kbps
Noise Margin 8.8 db 16.0 db
Not sure what to do now.
- « Previous
- Next »
