House move+10 day training
- House move+10 day training
- « Previous
- 1
- 2
- Next »
Re: House move+10 day training
07-07-2013 3:58 PM
Uptime: 0 days, 0:13:16
DSL Type: G.992.5 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,312 / 20,712
Bandwidth (Up/Down) [kbps/kbps]: 1,279 / 20,772
Data Transferred (Sent/Received) [MB/GB]: 6.32 / 208.82
Output Power (Up/Down) [dBm]: 12.0 / 16.5
Line Attenuation (Up/Down) [dB]: 7.5 / 9.5
SN Margin (Up/Down) [dB]: 7.0 / 3.0
Loss of Signal (Local/Remote): 4 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 5 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 117
HEC Errors (Up/Down): 1 / NA
Just need to get PN to nudge the profile as it never seems to raise by itself.
07-07-2013 5:50 PM
!st time,he set it to 16.4mb, then to 18.1.........but he *couldn`t* set it higher than that for whatever reason (ticket raised...tho there`s none showing in my member center), but just looking back in there and it`s now back to 16.4mb!
What reason would there be for PN not to be able to raise the profile to the correct ammount?
08-07-2013 8:34 AM
Bit of a issue with the CS i spoke to yesterday with regarding misinformation,but i`ll deal with that via tickets.
08-07-2013 2:02 PM
08-07-2013 4:35 PM
Thank you for sorting that Matt. 🙂
08-07-2013 8:50 PM
All`s well in Greenhithe tonight.
09-07-2013 9:05 AM
09-07-2013 11:52 PM
"I've ordered some changes to your line which should prevent the target SNR margin from dropping to 3dB again in the future, these changes will be made tomorrow (10/07/13) before midnight, and should provide continual protection from then onwards. " ...There are more details but you`ll see when you look.
Like i just stated in the reply to that ticket,i assumed that being less than 300 meters from the exchange and having a downstream att of 9db,having the snr @ 3db (adjusted by DLM from 6db....and predicted by OldJim!) would be expected from the 18,000kbps being a low sync for the distance/stats that i had and now being @...
Uptime: 0 days, 8:02:49
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,336 / 20,664
Bandwidth (Up/Down) [kbps/kbps]: 1,270 / 20,868
Data Transferred (Sent/Received) [MB/MB]: 48.36 / 686.31
.....with no noticeable problems everything would be fine!
Just trying to shut the stable door before the horse bolts really.
10-07-2013 3:33 PM
Looks like this order completed around 4am this morning, hope you've not noticed any changes to your sync speeds/profile? Please let us know either way, things are looking good from what we can see on our supplier's side of things.
11-07-2013 7:34 PM
Tho as per normal,the profile in the member centre needs a nudge to match the 19Mbps profile please.
12-07-2013 11:52 AM
- « Previous
- 1
- 2
- Next »
