Home Network Router Problem
- Home Network Router Problem
Re: Home Network Router Problem
22-07-2014 8:35 PM
If you type 192.168.1.254 into your browser url (address) bar or click the following link, you should get what's called the "Landing" or TG582n Information page I would bookmark this one if it works ok - handy for a quick check on your connection.
Does your page show you statistics for your Broadband connection? eg. Status Up and figures in the lines below.
I'm guessing in the Internet Connection box below it says not connected.
If it worked, you can get to the Login page either by clicking on <Advanced Options> at the bottom of that page (5.4) or click the link Login page and tell me what you get?
Edit: sorry I originally mistyped the address 192.168.1.254 now corrected.
If you get the tg582n login screen it should have the default admin username in the box and the password is the serial number..
22-07-2014 8:39 PM
That was with Chrome.
Tried with IE and get Error Message: "Sorry an error occurred while processing your request. ........website team will investigate...................
22-07-2014 8:41 PM
Ah, with ref your reply #29, can your type your Madasafish username into the box and your account password in the password box?
Note these are not the same as the TG582n login name and password.
The MAFF account name should be something of the format myaccountname@madasafish.net
I'm not familiar with MAFF login so I'm not sure if it's madasafish.net but PN should have told you exactly what it is - did they?
22-07-2014 8:45 PM
22-07-2014 8:59 PM
I have done that but it rejects it. It is .com by the way.
22-07-2014 9:03 PM
22-07-2014 9:07 PM
Quote from: Anotherone Sorry, in my reply #30 I should have typed 192.168.1.254 now edited and corrected.
Success!!!
I am in the Plusnet Technicolor Gateway. It shows Broadband Connected. Firewall Standard. Home Network: Ethernet Connection to PC but Wireless iPhone (which I don't understand)
22-07-2014 9:13 PM
22-07-2014 9:18 PM
22-07-2014 9:34 PM
22-07-2014 10:41 PM
22-07-2014 10:56 PM
One thing I should mention is that when you log into the 582n, it will log you out after 10 minutes of inactivity, so if you click on a link to a page it gives you the login screen first.
23-07-2014 9:20 AM
23-07-2014 10:50 AM
OK, looking at the router page http://192.168.1.254/cgi/b/is/_pppoa_/ov/?be=0&l0=2&l1=2&name=Internet (as reply #37) there should be some values similar to below - I've made up the numbers for the IPv4 Address - don't post yours, but does it show one? And what does it show for the Primary and Secondary DNS? (They may be different values). You can safely post those.
TCP/IPv4 Settings
IPv4 State: Enabled
IPv4 Address: 87.123.123.123
Primary DNS: 212.159.6.10
Secondary DNS: 212.159.6.9
By the way, do you know how to use Private/Personal Messages (PMs)? - they are under MY MESSAGES at the top of the board. You can also open one to compose to someone by clicking the little RH icon below their username on the left of a post. If you hover over the Icon it says Personal Message with Offline or Online depending on a red or green mark on the icon.
Edit: your DNS entries may be showing 212.159.13.49 & 212.159.13.50
23-07-2014 12:51 PM
IP address: 10.49.38.209
Primary DNS 212.159.6.9
Secondary DNS: 212.159.6.10
Checked connectivity and I have a full set of ticks
BUT I cannot connect to any site.
I didn't know how to send a PM but now I can. What would you like me to send?
