Higher than normal SNR margin after a line fault.
- Re: Higher than normal SNR margin after a line fau...
07-12-2012 4:25 PM
Hi.
We had a serious line fault a couple of weeks ago which resulted in our broadband going up and down rapidly for several days followed by no line at all (phone or broadband) for several days. This has been fixed now - about 4 days ago, but my SNR margin is now 12db with a sync speed of 1600. Normally it would be 6db with a sync speed of 20xx. Will this correct itself or does someone from Plusnet now need to go in and adjust the SNR margin for me?
The throughput is therefore rubbish at the moment and its very frustrating.
Regards
Regards
Message 1 of 4
(915 Views)
3 REPLIES 3
Re: Higher than normal SNR margin after a line fault.
07-12-2012 4:55 PM
Message 2 of 4
(434 Views)
07-12-2012 8:24 PM
Thank you Adam
Do you not need to know my user ID or do you already have it?
Regards
Regards
Message 3 of 4
(434 Views)
07-12-2012 9:42 PM
No, Plusnet know who you really are, 'FarmerGiles'.
Message 4 of 4
(434 Views)
