High-speed Broadband page details incorrect after house move
- High-speed Broadband page details incorrect after ...
01-02-2011 3:09 PM
Telephone number:
01?????????
Phone exchange:
LONGTON
Estimated line speed:
6Mb (Accurate to within +/- 1Mbit) - Checked on 2010-04-27 03:53:54
Current line speed:
7.15 Mb
Rgrds
Mark
Re: High-speed Broadband page details incorrect after house move
01-02-2011 4:02 PM
This should change when the records update.
Jojo
01-02-2011 4:14 PM
Mark
01-02-2011 4:32 PM
Jojo
01-02-2011 4:58 PM
Forum Moderator and Customer
02-02-2011 4:47 PM
I was trying to remember who else had mentioned this. Thanks. There is now a problem open on this and I will also add yours as an example.
Jojo
06-02-2011 11:46 PM
Just noticed your reply - sorry for the delayed thanks
07-02-2011 10:36 AM
It's ok now, but it is a year later
09-02-2011 10:59 AM
Mark
09-02-2011 1:10 PM
JoJo, I think I had the same problem in November, with my old number showing which changed the previous January. You can add me to the list! (I raised a ticket #36926223, and after some back and forth over a related issue, it was sorted.)
Edit: to put in details
09-02-2011 9:58 PM
No it makes no difference to your speed.
@snozboz, did you say it was resolved?
Jojo
09-02-2011 11:02 PM
Quote from: Joanne @snozboz, did you say it was resolved?
Yes, my iteration of the problem was resolved back then, as described in the ticket.
I just recognised the problem as the same I'd had, saw you were compiling some examples, and thought I'd add my name to the list - so hopefully you can get the general problem sorted, rather than having to fix each case as they are spotted (which is what happened with me).
09-02-2011 11:33 PM
Ah, I see. Thanks anyway but the examples I'm after are ones that are currently wrong.
Jojo
