High FEC error rates causing disconnections
- High FEC error rates causing disconnections
- « Previous
- 1
- 2
- Next »
Re: High FEC error rates causing disconnections
19-04-2010 9:10 AM
I swapped to an old Speedtouch 585 v6 yesterday and things did not get reset overnight as was happening with the 585 v7. SN Margin is a respectable 7.0 and bandwidth is good. Now all I need is for BT to reset the profile upwards.
DSL Connection
Link Information
Uptime: 0 days, 16:58:50
Modulation: G.992.1 Annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 3,776
Data Transferred (Sent/Received) [MB/MB]: 8.93 / 54.03
Output Power (Up/Down) [dBm]: 12.0 / 18.5
Line Attenuation (Up/Down) [dB]: 31.0 / 57.0
SN Margin (Up/Down) [dB]: 17.0 / 7.0
Vendor ID (Local/Remote): TMMB / µ
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 124 / 0
FEC Errors (Up/Down): 2 / 715,532
CRC Errors (Up/Down): 0 / 162
HEC Errors (Up/Down): 0 / 143
DSL Connection
Link Information
Message 16 of 18
(347 Views)
19-04-2010 10:38 AM
Hi antiquebrit,
Your profile on BTs side is showing at 3000 where ours was on 2000 - I've upped the one on our side to match, hope that helps.
Message 17 of 18
(347 Views)
19-04-2010 12:23 PM
Thanks Matt,
That did the trick. Now the next trick will be to keep it that way!
david
<a href="http://www.mybroadbandspeed.co.uk"><img src="http://www.mybroadbandspeed.co.uk/results/26363141.png" /></a>
david
Message 18 of 18
(347 Views)
- « Previous
- 1
- 2
- Next »
