High Downstream Rate - Poor Connection
- High Downstream Rate - Poor Connection
19-04-2009 7:31 PM
I am getting the following connection:
Status: Up
Downstream Rate: 2932 Kbps
Upstream Rate: 755 Kbps
PVC Connection
Encapsulation: RFC 2364 PPPoA
Multiplexing: VC
QoS: UBR
PCR:
SCR:
Autodetect: Enable
VPI: 0
VCI: 38
Enable: 1
PVC Status: Up
But when I run a speed test I am only getting a connection speed of 1100kbps
Anyhelp would be appreciated....
Status: Up
PVC Connection
Multiplexing: VC
QoS: UBR
PCR:
SCR:
Autodetect: Enable
VPI: 0
VCI: 38
Enable: 1
PVC Status: Up
Message 1 of 4
(1,177 Views)
3 REPLIES 3
Re: High Downstream Rate - Poor Connection
19-04-2009 8:22 PM
ip profiles is what will be holding your speed test results back. what do they say here https://portal.plus.net/my.html?action=data_transfer_speed and here http://www.speedtester.bt.com/
also if you can grab these stats from your router we can advise if your lines syncing at the right rate for you line
sync rate, noise margin/ snr, line attention
if you dont know how to grab these results from your router this page will help http://www.kitz.co.uk/adsl/frogstats.php
Message 2 of 4
(455 Views)
19-04-2009 9:30 PM
This is the information I get from Plusnet
Estimated line speed:
1.0 Mbps - Checked on 2008-12-09 16:42:44
Current line speed:
1250
This is the information from the Router
--- System Information ---
Vendor: Linksys
ModelName: WAG160N
Firmware Version: A1.00.12 , 2008-12-22T18:07:45
GUI Version: A1.00.12_007
Boot Version: 1.0.37-5.4
Hardware Version: 0.01
--- DSL Information ---
DSL Driver Version: AnnexA version - A2pB022g.d20e
DSL VPI/VCI: 0/38
DSL Status: ShowtimeRetrain Reason: 4
DSL Mode: ADSL2+
DSL Channel: FAST
DSL Upstream Rate: 762 Kbps
DSL Downstream Rate: 1627 Kbps
Down up
DSL Noise Margin: 6.2 dB 5.6 dB
DSL Attenuation: 61.5 dB 35.0 dB
DSL Transmit Power: 17.7 dBm 12.4 dBm
--- Wireless Information ---
Wireless Driver Version: 6.1.1.111
Wireless Tools Version: 28
Wireless Status: Enabled
Wireless Wide Channel: 9
Wireless Standard Channel: 11- 2.462GHZ
Wireless SSID: Home
--- Dynamic Information ---
LAN Mac Address: 00:1D:7E:B8:17:29
WAN Mac Address: 00:1D:7E:B8:17:2B
Wireless Mac Address: 00:1D:7E:B8:17:2A
Funnily enough since I have plugged my phone back in, the downstream rate has dropped quite a bit..
Current line speed:
1250
Vendor: Linksys
ModelName: WAG160N
DSL VPI/VCI: 0/38
DSL Mode: ADSL2+
DSL Channel: FAST
Down up
Wireless SSID: Home
Message 3 of 4
(455 Views)
19-04-2009 10:26 PM
I have re-booted the router and the stream has increased again.
Status: Up
Downstream Rate: 2594 Kbps
Upstream Rate: 735 Kbps
Status: Up
Message 4 of 4
(455 Views)
