High Attenuation & High SNR = continued confusion
- Re: High Attenuation & High SNR = continued confus...
- « Previous
- Next »
Re: High Attenuation & High SNR = continued confusion
17-08-2011 7:39 AM
Quote from: puddy ,,, After all PlusNet said the line faulty/ operating below an acceptable performance.
They did? I cannot see that anywhere in the statement you quoted. Surely for any line there is an acceptable range of performance and if the line falls below that then it is deemed faulty.
Message 31 of 36
(489 Views)
17-08-2011 10:24 PM
Quote from: Dexter619 Hello again
I waited for the 72 hour period to pass but hours before it was over the connection was lost for probably no more than seconds.. but due to this I presume it has stopped the ip profile going upto 2500kb/s as on bt speedtester it's still telling me 2000kb/s.
Is there anything I can do because since it has reset but only after it has passed nearly 2 days connected... :S I would hope the extra profile speed would make a difference as one minute it's so close to 72 hours and next minute it's disconnected and reconnected again
Thanks, Declan
Tonight I have used the BT Speedtester and verified the IP Profile up at 2500kb/s but the speed still at 1750kb/s with a sync speed of 2800kb/s. I presume after all of this action the line probably won't get any faster although still within the 10 day learning period still?
What also irritates me slightly off topic is that the government has all this money for rural broadband modernising although still rolling it out in towns... Anyways thanks for the help if my broadband can't physically get any faster in the mean time.
Message 32 of 36
(489 Views)
17-08-2011 11:28 PM
You should see increased speed once Current line speed in the Member Centre updates to match the IP Profile. That should happen automatically within 12 hours of the IP Profile change.
David
Message 33 of 36
(489 Views)
18-08-2011 4:23 PM
Thank you Spraxyt. I have noticed the connection slightly quicker today and just did a couple of tests and around 2.1/2.3 now so better than it was
Thank you for the help!
Message 34 of 36
(489 Views)
18-08-2011 4:30 PM
I've checked your line sync rate, IP profile and our profile for you and all show that the throughput should reach up to 2500kbps. The BT speed test result you obtained today at 2149kbps fits with the line test results.
Considering the high attenuation on your line (63dB) this is a good result!
Message 35 of 36
(489 Views)
19-08-2011 12:45 AM
Hi Alex,
Well I noticed it was quicker and I just hope the speed stays pretty much stable as in the past I was reaching 2000kb/s but only for minutes and then back down below 1500. So would be pleasing to see it stay above 2000kb/s without too much fluctuation.
Thanks again for your help. Top customer service Much appreciated!
Message 36 of 36
(490 Views)
- « Previous
- Next »
