Hi from me too!
- Hi from me too!
Re: Hi from me too!
14-04-2009 12:51 PM
Re: Hi from me too!
14-04-2009 12:54 PM
Re: Hi from me too!
14-04-2009 12:55 PM
As Oldjim said this is not correct, I believe there are two options here.
1) Replace JB with a BT Master socket. ( This is not allowed as only BT should wire the incoming cable to the master socket)
2) Identify which of the two cables goes to the existing master socket and remove the other one from the JB shown. If the extension from this is required then this should be re-routed or re-run from the Master socket to where it is required.
If it were me I would replace the JB shown with a new one wiring as in 2 above. The old JB is a very old design prior to the new IDC connections ans is showing signs of corrosion and could give rise to problems with the joints in it.
To summarise: The existing installation does not comply with BT's wiring and needs to be put right, doing this will almost certainly bring your speeds up to what your neighbours are getting. My preferred option is to get "someone" who knows what they are doing to fit a new Master socket to replace the old JB shown and wire new extensions from this, either using the existing cable which seems to be the correct CW1308 spec or new cable, which is not expensive.
I hope this is of some help.
Paul.
Re: Hi from me too!
14-04-2009 1:02 PM
In view of what you have said, my thoughts now are, if this wiring is not to BT specifications, should they not put that right free of charge? I would, of course, appreciate that the extension cabling within the house is my responsibility.
Re: Hi from me too!
14-04-2009 1:52 PM
yes please
Quote from: MommaCat Check! You want me to get a photo of the downstairs phone socket now, oldjim?
Re: Hi from me too!
14-04-2009 2:04 PM
Re: Hi from me too!
14-04-2009 2:08 PM
Re: Hi from me too!
14-04-2009 2:12 PM
Re: Hi from me too!
14-04-2009 2:21 PM
Oldjim - I notice others are uploading small pics from their hard drives, but I used Photobucket as I find it automatically resizes them for use on forums. Are small pictures preferred on this forum? If so, I will resize my Pics on the hard drive in future.
Re: Hi from me too!
14-04-2009 2:24 PM
Re: Hi from me too!
14-04-2009 2:31 PM
Re: Hi from me too!
14-04-2009 3:08 PM
Re: Hi from me too!
14-04-2009 3:49 PM
Re: Hi from me too!
14-04-2009 3:54 PM
I think all I can do now is wait and see what BT say - mind you I'm not hopeful of getting it done free. I do tend to use the P Word (Pensioner) when it suits me! If that does not work, I will ask for estimates and see what I can afford - just the box being renewed or re-wiring as well.
Thanks for all your assistance everybody!
Re: Hi from me too!
14-04-2009 4:00 PM
