Here we go again
- Here we go again
Here we go again
23-08-2007 11:20 AM
Re: Here we go again
23-08-2007 11:21 AM
Has your router resynced lower recently as this may have forced BT to reduce your IP profile and it will take a few days to sort itself out (i.e. get higher again)?
23-08-2007 11:25 AM
23-08-2007 11:27 AM
Have you tried rebooting your connection?
What speedtest results are you getting from http://www.mybroadbandspeed.co.uk ?
23-08-2007 11:33 AM
23-08-2007 11:54 AM
23-08-2007 11:58 AM
23-08-2007 12:10 PM
I've run a couple of checks on your line and there's nothing that would suggest why you are seeing those speeds.
As an initial step I would suggest changing your microfilter and ensuring that you are connecting to your master socket.
23-08-2007 12:53 PM
23-08-2007 1:37 PM
Thanks for letting me know. Your best bet is to start (and complete) the Broadband Faults Tool, which will then allow us to investigate your problem further and subsequently raise to BT.
http://faults.plus.net
23-08-2007 1:39 PM
