Here we go again :(
- Here we go again :(
Here we go again :(
01-04-2014 10:26 PM
Ok i need this sorting its been going on now nearly 3 weeks , its definitely not the router as i have now tried 4 different ones and cant be all bad ones, my speeds are back down to 29mb , i was using my TG589vn v3 thinking that could be the problem i set up the 582 with the bt modem and getting similar speeds again 29mb, i then just tried the bt modem my speeds went back up to 66/67mb so thinking the 582 was the problem was sent a replacement 582 speeds still sat at 29mb , in the meantime i bought myself another TG589vn v3 and my speeds are still 29mb, tried just the bt modem again and speeds back upto 66/67mb what is going on.
Re: Here we go again :(
01-04-2014 10:37 PM
02-04-2014 7:06 AM
Ok another test this morning no change to me this looks like am being capped at 29mb, every test is 29mb
03-04-2014 9:23 AM
03-04-2014 10:36 AM
Yes i have tried a different cable am on my 3rd new one (cat 6 ) , all tests are wired as my desktop pc`s wireless is disabled ( on purpose by me cause i hate using wireless personal opinion) . Wireless at the minute is disabled on router till i get this sorted , so no other devices are using it at the moment, ( Which is causing problems at home ). I am now on my 4th router, i have bought another tg589vn v3 as its a very stable router and wireless is much better, but again this has made no change so wasted more money. So i have now tried two 582`s and two tg589`s and still getting same results.
Andy.......
03-04-2014 12:26 PM
03-04-2014 12:55 PM
speeds are no better and router is just across the room.
03-04-2014 12:56 PM
03-04-2014 1:00 PM
03-04-2014 1:21 PM
*edit* tried running btw speedtest but it needed flash and got error when trying to install it device doesnt support it.
03-04-2014 4:02 PM
03-04-2014 4:33 PM
03-04-2014 5:01 PM
03-04-2014 5:37 PM
04-04-2014 11:14 AM
I guess prior to 3 weeks ago all speed tests were OK? Just looking to see if anything changed at that time.
