Help - settings for Belkin router
- Help - settings for Belkin router
27-01-2010 10:17 AM
I am installing a new Belkin router and it doesn't appear to work with Plusnet.
I rang Plusnet tech support last night and after waiting 25 minutes to get through I was then told he couldn't help as he '..hadn't been trained...'. Oh.
Does anyone have the full settings? I have followed the settings off the main Plusnet support pages, but I still can't get online even though I have a connection!
The router is a Belkin MIMO G+ and does not have PPPoA as an option.
Message 1 of 3
(3,580 Views)
2 REPLIES 2
Re: Help - settings for Belkin router
27-01-2010 2:14 PM
Did you buy the router from a supplier in this country so it has UK firmware on it? When I used a Belkin MIMO G+ router a couple of years ago it had PPPoA available. In fact the default (factory reset) settings were OK, all I had to enter were my broadband username (probably username@plusdsl.net if you are a Plusnet customer) and password.
The full connection settings you need are given on this Help and Support page.
David
Message 2 of 3
(952 Views)
28-01-2010 9:20 AM
Hi. Yes, I bought the router directly from Belkin UK, but there is definitely no PPPoA setting (though there is everything else). I will have another look tonight.
Message 3 of 3
(952 Views)
