Help required can't login to router
- Help required can't login to router
- « Previous
- 1
- 2
- Next »
Re: Help required can't login to router
22-08-2007 8:14 AM
It does have it's own interface as i could get to it last week.
All you had to do was type 192.168.1.1 into the browser and off it went.
At work for time being so can't do anything right now.
Will the link you sent me help to achive a static IP and port forwarding but just not via the router?
If so do i just follow With a public IP-range subnet (No-NAT service) Have not used TELNET before.
Message 16 of 22
(549 Views)
22-08-2007 11:45 AM
The link I gave indicates the router does not have a web interface but the portforward website suggests it does so I am confused.
What PlusNet product are you on as only certain ones have a static IP? The legacy product PAYG and premier have a static IP, BB+ does not. The new BBYW products have a dynamic IP although if you changed from a legacy product that did have a static IP you can request a static IP to be used. You do this via a ticket.
You should be able to do everything via telnet although not necessarily as easy. Can you check that this works.
The only other suggestion is to reset the router back to its factory default settings but that may mean you can't use it if the web interface still does not work. You will have to use the telnet interface then to reconfigure it.
Message 17 of 22
(549 Views)
22-08-2007 2:44 PM
Am on Broadband Prem option 1
Spoke to a guy at work about it and he thinks it might be because i set up a static ip before i installed XP that the IP for the router might have changed possibly to 192.168.1.2
failing that i will re-install the zyxel disk, set up the LAN again and try accessing the interface that way.
Failing that further i will try telnet!
Will keep you posted Peter!
I know it does have it's own interface, the instructions from portforward.com are the ones i'm using too.
Steve
Steve
Message 18 of 22
(549 Views)
22-08-2007 2:52 PM
The router must be on 192.168.1.1 as that is the default gateway you are using. A telnet to that IP will prove this.
I'm wondering if the web interface has somehow been disabled so does not respond to port 80 connections. A factory reset should sort that out - and the routers default ip is 192.168.1.1 as far as I know.
Message 19 of 22
(549 Views)
22-08-2007 3:28 PM
How would i do a factory reset?
Message 20 of 22
(549 Views)
22-08-2007 3:34 PM
There should be a pin sized hole in the back of your router. Hold this down for 10-15 second and this should perform a factory reset.
Message 21 of 22
(549 Views)
22-08-2007 5:56 PM
Success!
IP login was 192.168.1.1:81
Thanks for all your help
Message 22 of 22
(549 Views)
- « Previous
- 1
- 2
- Next »
