Help me troubleshoot an issue connecting to a cod 4 server
For some reason totally unknown to me I cant connect to CoD 4 server I know is online.  Here is some screenshots.  It might be helpful if anyone who has cod 4 can see if they can connect to it Cheesy
193.200.158.48:28961
Anyway shot one.  Server on server list.  No ping or server name.  Sometimes it does show how many players are in the game and the name of the map, but never a ping.  When I try and connect it times out after 10 seconds
So I tried pinging the server, which worked.  At least I know it exists
Next I tried doing a trace route.  No problems there either;
I've checked, double checked and triple checked my firewall settings, the port is open.
This makes no sense to me, why can't I connect to it.  I asked the server admin who said there is no reason from his end why I can't connect.
Hope someone can help Smiley
Ta
20 REPLIES 20
Re: Help me troubleshoot an issue connecting to a cod 4 server
If you have a software firewall try disabling it temporarily to see if it makes any difference. If you have the PN firewall enabled turn that off (and reboot router afterwards).
I assume you have rebooted your router & PC?
No software firewall.  And no PN firewall that I am aware of... Ill make sure though.
I haven't actually tried rebooting router which was dopey of me. Will try that in the morning
Reboot did nothing...
im a cod4 player, what msg do you get when you are disconnected?
there are 3 i know of,
connection timeout
server disconnected
low ping players only
let me know if it is any of the above as there is fixes for these
or if it isn't post what msg you get and il look into it.
Ive also tried that server using ase and it has a dynamic ip address so it wont show up. have you got the correct port number/ip ?
I think im getting connection timeout but I'm not on my windows box at the moment.  I'll check again tomorrow.
Yeah it's definitely the right IP and port although apparently there were some issues over the last few days where people couldn't connect, but mine I have been able to connect at all over a 2 week period.  Ill try connecting again tomorrow.
Cheers
Fixes: 9
Does this resemble your experience at all?
big long link
Kelly Dorset
Broadband Service Manager
Fixes: 10
LOL - I wondered that.
But he's on ptn-ag2 (see the trace he's given)
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Fixes: 9
No, I'm not thinking about an LLU line, more just wondering if there is something p2p that we aren't catching properly so at peak it's getting de-prioritised?
Kelly Dorset
Well it's fixed now...
Did anyone do anything?
Fixes: 9
Don't think so.  Can you try at about 8pm?
Kelly Dorset
Sure
Fixes: 9
We got a copy of the game tested internally this afternoon and it DOES appear that we aren't profiling some of the traffic properly.
I've raised a problem to get this sorted.
Kelly Dorset
Who drew the "short straw" having to test this, eh? Wink
From my perspective, COD4 on the PC seems to be profiled just fine. Smiley
B.
Fixes: 9
Are you using Punkbuster with it?
Kelly Dorset
