Help With Broadband Package
- Re: Help With Broadband Package
22-07-2009 4:38 PM
Hi There.
Ive been a PlusNet Customer for quite some time and been on the same package.
Basically its Upto 8mb Premier (20:1 Contention Ratio & 800kbps Upload).
Thing is i'm wondering if I should move product because I'm not exactly happy about the Cost and what I've been getting from it for the past few months.
I mean I get Upto 8mb, my usage allowance is around 20gb and unlimited usage from 12am - 4pm which is Good.
The only thing that bothers me is the traffic prioritisation during the daytime (anytime during non unlimited usage hours).
Download Speeds from 12am - 4pm will be on average at 870kb/s
Download Speeds during 4pm - 12am will be Maximum 50kb/s via p2p, Usenet, anything.
What i need advice on is whether I should change my product to Broadband Pro as the traffic prioritisation from what they say, is much higher.
At the moment im paying £31.31, and im sure for this I should be getting higher speeds during daytime. I dont know how much difference the contention ratio will be if its like everyone else (50:1).
Does anyone who is on the PlusNet Pro package get the same/ decent download (and Upload) speeds anytime during the day?
And how much Upload is on this package (448kbps/832kbps)
Or anyone who was on an old PlusNet Premier package notice any difference between speed if theyve migrated to the new packages.
Thanks for helping
Thanks for helping
Message 1 of 6
(1,008 Views)
5 REPLIES 5
22-07-2009 4:40 PM
You may wish to look here http://www.kitz.co.uk/isp/plusnet_shaping.htm.
Message 2 of 6
(576 Views)
22-07-2009 4:43 PM
The one thing to note is that PRO you get 15GB per month between 8AM and Midnight not 4PM and midnight.
If you are using 20GB between 4PM and Midnight now I suspect moving to pro would be quite expensive for you.
Contention as such doesn't exist anymore so you'd be the same whichever product you went on.
832k upload is chargeable add on for all home packages, unless your on the ADSL2 trial.
Message 3 of 6
(576 Views)
22-07-2009 4:58 PM
Hmm , times that I'm on varies so not sure. Think I'll stick with what im on for a few months Lol. Thanks for both of your help , appreciate it :
Message 4 of 6
(576 Views)
22-07-2009 4:58 PM
Doesn't Max Premium (up to 832 upload) also get a better BT network priority? (replacing the 50:1 - 20:1 difference)
Max Premium and ADSL 2+ trial can both be requested from http://portal.plus.net/wizard/?wizard_id=20
Message 5 of 6
(576 Views)
22-07-2009 5:01 PM
Yep - IPStream Max Premium offers increased traffic priority over the BT Network.
Message 6 of 6
(576 Views)
