Has my Broadband Product been changed?
- Has my Broadband Product been changed?
- « Previous
- 1
- 2
- Next »
Re: Has my Broadband Product been changed?
12-11-2011 12:08 PM
Odd - it must be something to do with being on a legacy product
Message 16 of 20
(240 Views)
12-11-2011 5:14 PM
Quote from: Oldjim Looking at the present month the total usage to date is 38.44GB so Value is a total non starter
Yes, I had not noticed that. But I used 33 GB last month on the Value package of which just under 10GB was during 8 am until midnight and the remaining 23 GB was between midnight and 8 am. You can still achieve large total figures on Value if you are careful enough and are either a night-owl or an early riser.
Message 17 of 20
(240 Views)
13-11-2011 1:15 AM
Quote from: Oldjim I get this screen
@Oldjim - you may want to edit that graphic - it has your telephone number and postcode visible...
Message 18 of 20
(240 Views)
14-11-2011 10:26 AM
So looks like I am going to switch from Broadband Plus up to 8Mb to Plusnet Extra...
As I apparently cannot switch back once I have changed product can anyone see a downside to this?
My usage seems to vary between 10 and 40Gb per month, just worried that I might be worse off or am missing something in the T&Cs if I switch..
Message 19 of 20
(240 Views)
14-11-2011 10:34 AM
Fixed thanks
Quote from: Jaggies
Message 20 of 20
(240 Views)
- « Previous
- 1
- 2
- Next »
