Hardline fault just about to move to plusnet
- Hardline fault just about to move to plusnet
20-03-2019 12:52 PM
We are about to move to Plusnet, go live date is 25 of this month, however today we seem to have developed a "hard line" fault diagnosed by our old ISP tech support.
But because we are moving in 5 days they won't send an engineer to fix the problem.
What will happen once we move to Plusnet, how will the problem be resolved.
It seems a bit s##ty that they the old isp are walking away leave Plusnet to fix the problem!
Re: Hardline fault just about to move to plusnet
20-03-2019 1:08 PM
Welcome aboard & to the Forums.
At the moment in time, it's hard to say what's going to happen in regards to your transfer - the fault will still be there, so we will have to see if it affects the orders completing.
I've never heard of companies washing their hands of people before the end of their contract...that's interesting, who is the old ISP may I ask?
Once we get the orders on the move we will be made aware if the fault is going to cause an issue and, if so, we can take it from there.
Kind Regards,
MoR
20-03-2019 1:22 PM
20-03-2019 1:41 PM
When they say "gone to Openreach" do you know if they have raised this as a fault, or if they mean that the transfer order has gone to Openreach?
Regardless, they should still look into this as you are (at the moment in time) still a customer of theirs.
If I were you I'd give them a bell and see if you get a different outcome this time - or at least a better explanation.
Kind Regards,
MoR
20-03-2019 2:29 PM
That what I've been told today via twitter conversation!
I'll try a different route, but as you've said we are still their customer!
20-03-2019 4:17 PM - edited 20-03-2019 4:23 PM
I'm not completely sure so don't quote me on it but whilst they provide the service I think you have the right to expect the fault to be fixed by them. You could check their terms and conditions which should outline their responsibilities to you so if it's in there that you're covered to the end then they shouldn't refuse. Failing that in the same position I would ask if they can reimburse you for the period the fault was found until the end of the contract.
