Had problems since before Xmas with Broadband connected but random no internet. Anyone help please?
- Had problems since before Xmas with Broadband conn...
Re: Had problems since before Xmas with Broadband connected but random no internet. Anyone help plea
09-04-2021 9:14 PM - edited 09-04-2021 9:16 PM
Been stable quite a while ..I think... as not checked for a while. Not the usual frequent drops any more, though speed is now lower than before. At first after the lift and shift and download pinned at 9dB, I had several times when the samsung smart tv catchup just stopped, just kept buffering, then an error message. Not had that happen for a very long time. However, seems to be behaving normally again last 2 weeks or so.
Log just now:
9 April 2104 power off 10 mins yesterday afternoon, hence the drop
6 - Uptime: |
1 days 06:49:24 |
7 - Data rate: |
756/8272 |
8 - Maximum data rate: |
1152/8416 |
9 - Noise margin: |
8.5/7.7 |
10 - Line attenuation: |
21.8/40.0 |
12 - Data sent/received: |
168.1M/1.7G |
Thanks, Robin
10-04-2021 11:28 AM
10-04-2021 3:59 PM
@Townman It doesn't work with my current router and couldn't get it to work with another old one either.
Other than the tv catchup just after OR repair, I have not been aware of any drops at all.
The engineer was very thorough and kept me informed of what he was doing. He also changed me over to a different pair from the manhole outside our house right into the exchange. He checked it right through from each cabinet to cabinet and also fitted crimp connections on the pole outside to replace the screw terminals with verdigris.
Rob
11-04-2021 12:15 PM
At 0020 this morning, it had dropped out. Was reset 0700ish this morning.
6 - Uptime: | 0 days 05:32:22 |
7 - Data rate: | 756/8065 |
8 - Maximum data rate: | 1160/8844 |
9 - Noise margin: | 8.9/9.0 |
10 - Line attenuation: | 21.8/40.0 |
12 - Data sent/received: | 19.2M/135.3M |
Robin
07-06-2021 8:54 PM
@Gandalf Last few days, getting a lot of buffering on tv and web pages sometimes taking 30 or more seconds to refresh.
It seems my speeds cannot "find their own level" as disconnecting router and powering up again usually results in no change after several days even.
When this happens, the Internet led is flashing rapidly.
Just now,:
6 - Uptime: | 14 days 14:35:11 |
7 - Data rate: | 756/8050 |
8 - Maximum data rate: | 1160/8528 |
9 - Noise margin: | 6.8/8.5 |
10 - Line attenuation: | 22.0/40.0 |
12 - Data sent/received: | 2.6G/594.2M |
Any ideas?
Rob
08-06-2021 8:40 AM - edited 08-06-2021 8:41 AM
Hi Rob, Sorry to see you're still having issues with your connection.
I've tested your line and the tests aren't showing any issues, with your broadband being stable with no drops for the last 15 days. I've attached the testing results below but they basically agree with your router stats.
Just to confirm, is the device you're using connecting wirelessly to the router or plugged in using an ethernet cable?
xDSL Status Check | |||
Circuit ID: | [redacted CBUK] | Service ID: | [redacted BBEU] |
Telephone NO.: | NA | Test Executed On: | 08-06-2021 08:34:48 |
xDSL Status Test Summary | |||||
Sync Status: | Circuit In Sync | ||||
General Information | |||||
NTE Status: | NTE Power Status: | Unknown | Bypass Status: |
Upstream DSL Link Information | Downstream DSL Link Information | |
Loop Loss: | 22.0 | 40.0 |
SNR Margin: | 6.8 | 8.9 |
Errored Seconds: | 0 | 0 |
HEC Errors: | 0 | |
Cell Count: | 588 | 2079 |
Speed: | 756 | 8048 |
Maximum Stable Rate (KBPS): | 2848 | Fault Threshold Rate (KBPS): | 2278 | ||
Mean Time Between Retrains (Seconds): | 86400 | Mean Time Between Errors Upstream (Seconds): | 6646 | ||
Indicative Line Quality: | G | Mean Time Between Errors Downstream (Seconds): | 255 | ||
Custom Thresholds | |||||
MTBR_RED: | MTBE_RED: | ||||
MTBR_GREEN: | MTBE_GREEN: |
08-06-2021 9:23 AM
Why might the DS SNRM be circa 9dB? Does that and the rather low DS MTBE point to any concern? Whilst the link is stable, might buffering point to high retransmission rates?
Might the user running a QLT find an issue not detected by the remote line test?
08-06-2021 9:29 AM
@Gandalf Thanks for the prompt attention!
It is the PN supplied 2704N and connects directly to my W10 pc (also older W7 pc occasionally used) approx a 2M network cable. I always give data from my pc, not a phone.
Looking at router Internet led now it is constant green.
When internet starts playing up trying to view webpages, a glance at router shows the constant rapid flickering.
The tv is mostly used late in the night on iplayer and is the only thing in use with internet.
I seem to recall that something was "pinned" at a max speed on my broadband back when all the troubles were really bad?
3 screenshots I previously saved.
24 May 0648 Had dropped out in night
6 - Uptime: |
0 days 00:03:26 |
7 - Data rate: |
756/8050 |
1160/8756 |
9 - Noise margin: |
8.2/9.0 |
22.0/40.0 |
683.6K/2.8M |
and
16 May 1442
6 - Uptime: |
5 days 21:54:00 |
7 - Data rate: |
756/7955 |
1156/8828 |
9 - Noise margin: |
5.4/9.3 |
22.1/40.5 |
1.4G/1.8G |
17 May 1657 after short power down to reset.
6 - Uptime: |
0 days 00:00:52 |
7 - Data rate: |
756/7870 |
1168/8636 |
9 - Noise margin: |
6.9/9.1 |
22.2/40.5 |
156.7K/168.9K |
Thanks, Rob
08-06-2021 9:33 AM
@joseph1 Thanks for the quick post back. It's normal for the internet light to flicker although it's not normal for you to have the issues you've described though. I'd like to replace the router as the next step, unless you have another one you can try?
@Townman Looking back at the history of the problem, the SNRM was pinned at 9dB to keep the line stable.
08-06-2021 9:38 AM
9dB to keep the line stable hints at the possibility of intermittent REIN or SHINE. Access to a Plusnet Hub One would permit detailed monitoring of the line's behaviour using the special version of Router Stats designed to work with the BT HH5a.
08-06-2021 9:43 AM
Potentially but if the line remains stable and all's good at 9dB we won't need to go back down the path of engineer visits.
Let's see what Rob comes back with as he may already have a different router to try.
08-06-2021 10:45 AM
Thanks again. I only have my previous pn router, the Technicolor. It was replaced as suspect due to age maybe 3 or 4 years ago when I had previous problems. That didn't make any difference back then, so I imagine it is still ok? Whether compatible with routerstats, I don't know.
I use an "old fashioned" transformer psu, rather than modern noisy smps.
Rob
08-06-2021 11:09 AM
08-06-2021 11:58 AM
08-06-2021 12:12 PM
Hi Rob,
The 2704n is most certainly not amenable to being monitored!
