HTTPI, Protocol or small webserver?
- Re: HTTPI, Protocol or small webserver?
22-08-2013 8:12 PM
What is this line in the router used for,
9 HTTPI tcp 8080 enabled
Is it for external web access to the router, ie a small web server, or is it allowing the HTTPI Protocol to work returning on port 8080.
Or neither ?
Regards
Gary
Or neither ?
Regards
Gary
Message 1 of 6
(2,827 Views)
5 REPLIES 5
22-08-2013 8:41 PM
I believe it's something to do with "web Browsing Interception".
If you disable the above in the GUI then the HTTPI service becomes disabled.
Message 2 of 6
(538 Views)
22-08-2013 9:19 PM
Strange, i have web Browsing Interception disabled, i just checked to make sure.
Very odd.
Very odd.
Message 3 of 6
(538 Views)
22-08-2013 9:48 PM
Using firmware version 8.C.M.0
With web Browsing Interception disabled.
service system list name=HTTPI expand=enabled
Idx Name Protocol SrcPort DstPort Group
1 HTTPI tcp 8080
Description................ HTTP intercept proxy
Properties................. proxy
Attributes................. state port srcip aclip aclif aclifgroup map log forward qoslabel routelabel natpmweight
User Managed Attributes.... map log natpmweight
Attribute Values :
State...................... (administratively) disabled
Port....................... 8080
Source Ip Selection........ auto
QOS Label.................. None
Route Label................ None
NAT Portmap Weight ........ 30
Ip Access List............. any
Interface Access List...... any
Interface Group Access List any
Map List................... 80:LocalNetwork 1080:LocalNetwork 8080:LocalNetwork
Logging.................... disabled
Forwarding................. enabled
1 HTTPI tcp 8080
Attribute Values :
Message 4 of 6
(538 Views)
22-08-2013 10:09 PM
What the hell is goin' on...
Message 5 of 6
(538 Views)
22-08-2013 10:31 PM
Ok so i've restarted my Router earlier today and i do recall turning off that web interception, but it's been up for 44 days and this would be the first time i've restarted it.
I just tried to enable the service from the cli and it appears still disabled after saving etc, so i guess it makes sense that the Router will only make changes after a warm reset etc.
So back to the point in hand, HTTPI=Web Browsing Interception.
cheers npr
cheers npr
Message 6 of 6
(538 Views)
