HORRENDOUS download speeds even to PN sites
- HORRENDOUS download speeds even to PN sites
02-04-2011 12:56 PM
I have an (unprecedented) 730kbps download connection... according to my router. For me this is "ludicrous speed". However...
It has taken my browser the better part of half an hour from opening Firefox to getting this page to load and I am also trying to download Firefox 4 which Firefox is telling me is progressing at the fantastic rate of 535 BYTES per second. Internet Explorer is giving me similar pathetic results.
DNS is resolving near-instantly so it's not that... I set up two (throttled) torrents to test pure IP connectivity and that's working fine as well. I've variously tried turning NAT on and off, the broadband firewall on and off, completely turned off my software firewall / antivirus... safe to say it's nothing at that end.
So what's going on?
Quote Tracing route to community.plus.net [212.159.8.110]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.1.254
2 1418 ms 1505 ms 1211 ms lo0-central2.pcl-ag02.plus.net [195.166.128.236]
3 1072 ms 1091 ms 583 ms gi1-24-221.pcl-gw01.plus.net [84.92.6.40]
4 557 ms 843 ms 738 ms po5.ptn-gw01.plus.net [212.159.1.131]
5 1455 ms 841 ms 365 ms gi3-0.pih-cr1.plus.net [212.159.1.177]
6 438 ms 491 ms 299 ms if25.pih-lb03.plus.net [212.159.0.17]
7 315 ms 281 ms 41 ms community.plus.net [212.159.8.110]
Trace complete.
C:\Documents and Settings\Tim>tracert community.plus.net
2 837 ms 1079 ms 1643 ms lo0-central2.pcl-ag02.plus.net [195.166.128.236]
3 1217 ms 1451 ms * gi1-24-221.pcl-gw01.plus.net [84.92.6.40]
4 * * * Request timed out.
5 865 ms 1362 ms * gi3-0.pih-cr1.plus.net [212.159.1.177]
6 * * 1740 ms if25.pih-lb03.plus.net [212.159.0.17]
7 1211 ms 825 ms 1035 ms community.plus.net [212.159.8.110]
This is literally unusable.
Oddly, some sites seem reasonably usable - the Google home page for Firefox (for example) loads up in a blisteringly fast twelve seconds.
If you don't get a reply from me over the weekend, please assume I've lost the will to live after accidentally hitting F5.
Re: HORRENDOUS download speeds even to PN sites
02-04-2011 1:44 PM
Also what does this say for current line speed https://portal.plus.net/my.html?action=data_transfer_speed
Also please post the current router stats - speeds, noise margin and attewnuation.
Normally I would suggest the BT speedtest but with those problems it would take for ever.
02-04-2011 2:18 PM
For interest, I posted the last message at 12:50 so it took the better part of an hour to post the message!
I hit the "reply" button to your message (after turning "download images" off in the browser) at 2pm and it's just loaded the page... at 14:07.
It's a wired connection to a Bipac router.
Quote ADSL Firmware Version : FwVer:3.10.5.0_TC3085 HwVer:T14.F7_1.0
Line State : Showtime
Modulation : G.DMT
Annex Mode : ANNEX_A
SNR Margin : 7.0db down, 9.0 db up
Line Attenuation : 63.5db down, 31.5db up
Data Rate : 736kbps down, 448kbps up
Given up trying to load the speed test, because after 10 minutes it's still not finished loading the page.
A tracert to www.plus.net achieved this:
Quote 1 <1 ms <1 ms <1 ms 192.168.1.254
2 1277 ms 1041 ms 903 ms lo0-central2.pcl-ag02.plus.net [195.166.128.236]
3 * * * Request timed out.
4 * 1117 ms 1287 ms po5.ptn-gw01.plus.net [212.159.1.131]
5 1631 ms 1541 ms 1257 ms gi3-0.pih-cr1.plus.net [212.159.1.177]
6 1333 ms 1404 ms 1572 ms if25.pih-lb03.plus.net [212.159.0.17]
7 1117 ms 1387 ms 1897 ms portal.plus.net [212.159.8.2]
I tried a traceroute to cnn.com and it's just timing out after exiting the internal PN network.
Quote Tracing route to www.cnn.com [157.166.255.18]
2 * 1164 ms 1349 ms lo0-central2.pcl-ag02.plus.net [195.166.128.236
3 1149 ms 1545 ms 1407 ms gi1-24-221.pcl-gw01.plus.net [84.92.6.40]
4 1499 ms 1773 ms 1285 ms po4.pcl-gw02.plus.net [212.159.1.129]
5 1275 ms 973 ms 1909 ms 195.50.122.129
6 1415 ms * 1027 ms ae-34-52.ebr2.London1.Level3.net [4.69.139.97]
7 * 1211 ms 1513 ms ae-41-41.ebr1.NewYork1.Level3.net [4.69.137.66]
8 * * * Request timed out.
9 * * * Request timed out.
10 1378 ms 1139 ms 1521 ms ae-6-6.ebr1.Atlanta2.Level3.net [4.69.148.105]
11 * * * Request timed out.
12 * * * Request timed out.
13 * * * Request timed out.
14 * * * Request timed out.
15 * * * Request timed out.
16 * * * Request timed out.
17 * * * Request timed out.
18 * * * Request timed out.
19 * * * Request timed out.
20 * * * Request timed out.
21 * * * Request timed out.
Normally I would expect this tracert to go out to level3.net hosts in London and New York but it's timing out at that point.
So something outside my LAN is the issue, but whether or not it's something PN should be addressing or not, I can't say. Obviously, the way the internet is designed, it should be able to cope with this... and if it's an issue States-side, then why is it affecting my ability to use the PN site and community forums?
The clock on my PC has just bounced over to 14:19 so look at the date/time stamp of the message. It should be 14:19 or thereabouts.
02-04-2011 2:23 PM
02-04-2011 2:43 PM
This is completely screwed up.
By the way, I'm still waiting for the "https://portal.plus.net/m...ction=data_transfer_speed" page to finish loading. It's so far got to the point where Firefox has identified the page title as "Member Centre" and the certificate for the SSL connection, and is waiting for a reply from portal.plus.net.
In that browser tab the page has been blank for 20 minutes but it hasn't timed out so it has a connection, albeit one that's slower than 9600 baud dialup on a go-slow.
According to the network diags, the WAN interface is downloading about 50 bytes every 2 seconds.
Router diags say:
Quote >> Testing Ethernet LAN connection ... PASS
>> Testing ADSL Synchronization . PASS
>> Testing ATM OAM segment ping ... PASS
>> Testing ATM OAM end to end ping ... PASS
>> Ping Primary Domain Name Server . PASS
>> Ping www.yahoo.com ... PASS
Posting this message at... 14:42 by my clock.
02-04-2011 2:44 PM
02-04-2011 2:53 PM
Happily, the login page for portal.plus.net has FINALLY finished loading!
02-04-2011 2:54 PM
Quote [tt]traceroute to www.plus.net (212.159.9.2), 30 hops max, 60 byte packets
1 router.xxx.org.uk (192.168.0.1) 0.556 ms 1.163 ms 1.450 ms
2 lo0-homesurf.pcl-ag01.plus.net (195.166.128.28) 18.781 ms 20.599 ms 23.499 ms
3 gi1-2-805.pcl-gw01.plus.net (84.92.5.64) 140.078 ms 140.181 ms 140.431 ms
4 gi5-8.ptp-cr01.plus.net (84.93.224.48) 30.581 ms 32.860 ms 35.294 ms
5 vlan2658.ptp-elb02.plus.net (84.93.224.45) 36.762 ms 39.641 ms 42.526 ms
6 vlan2658.ptp-elb02.plus.net (84.93.224.45) 43.449 ms 44.304 ms 45.456 ms
[/tt]
Those suggest that there's a really bad delay between you and PN's edge router. The three areas of concern would be:
- Your ADSL link
- BT's exchange, backhaul, and core IP network
- Plusnet's "central" connection pipe.
There is little you can do about the second item.
The third one you can check - with this URL: http://usertools.plus.net/@gateway/.
You seem to be on "lo0-central2.pcl-ag02.plus.net", so I'm guessing pcl-ag02.
Packet loss can then be seen here: http://www.plus.net/support/service/network_performance/broadband_packets_drop.shtml
If there is a problem, you can try disconnecting, and getting re-allocated to a different pipe.
The first item seems more likely to me... but rather than disconnections, perhaps you are seeing a lot of errors on the line, which are causing delays in sending your packets.
Someone on here had a problem like this in the last few days, where they were getting 200,000 errors per hour - around 95% of their line capacity. They had great problems in getting web pages to finish loading too.
What error figures (CRC, FEC, ES, SES) is your modem reporting? And how are they changing over (say) a 5 minute period?
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
02-04-2011 7:07 PM
03-04-2011 2:00 PM
>> Ping www.yahoo.com ... FAIL
Connection Type : PPPoA
IP Address : 87.112.154.204
Subnet Mask : 255.255.255.255
Default Gateway : 195.166.128.242
DNS Server : 208.67.222.222
Modulation : G.DMT
SNR Margin : 7.5db Downstream, 8.0db Upstream
Line Attenuation : 63.5db Downstream, 31.5db Upstream
Data Rate : 736kbps Downstream, 448 kbps Upstream
I cannot even get usertools.plus.net to load so cannot check ANY of those settings, the speed test won't load. It's taking 10 minutes for the google home page to load (and that's the one with just the search box and search options, NOT the portal page).
I'm literally having to turn images off just to get pages like this to load and even then it is taking in the order of 30 minutes to actually get to a point where it displays the content and I can respond.
The only error I am seeing on the router is "WANIPConnection->GetGenericPortMappingEntry failed" which is to do with port forwarding (which I don't have configured).
I still have no idea why, if I hit Submit on this page, the response is posted up in a matter of a minute or so but it takes 20 minutes for my browser to get round to showing the target page.
Anyone from PN around who's reading this thread.... HELP! I can raise a call from the office tomorrow, but there's no way I can do it from here. Heck, even Windows Live Messenger is unable to track my status because it's so sllllllllllllooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooww
03-04-2011 3:26 PM
04-04-2011 7:55 AM
Quote 7:43:54.07 >tracert portal.plus.net
Tracing route to portal.plus.net [212.159.8.2]
3 * 866 ms 713 ms gi7-5-531.pcl-gw01.plus.net [84.93.254.65]
4 1288 ms * * po5.ptn-gw01.plus.net [212.159.1.131]
5 1095 ms 1447 ms 727 ms gi3-0.pih-cr1.plus.net [212.159.1.177]
6 1084 ms 1401 ms 1231 ms if25.pih-lb03.plus.net [212.159.0.17]
7 991 ms * 795 ms portal.plus.net [212.159.8.2]
Trace complete.
7:44:46.84 >
52 seconds to trace the route from a broadband connection to the PN portal is ludicrous but I haven't seen better than this (from home) for over a week!
Now I have disconnected and reconnected the router well over ten times in the past 48 hours and been connecting to different gateways and the latency does appear to be on the PN network.
My router is still saying there's no collisions, no packet loss, no TCP timeouts and no name resolution issues, but does still occasionally fail the PING test to non-PN hosts.
BitTorrent, perversely, is the only thing running on my machine right now that doesn't seem affected in the slightest (although it's still very slow, ~14kB/s download at best with two high-seeded torrents on the go) and that's despite the fact I've set the antivirus/firewall up to treat BT traffic on a set port, to be checked - ports 80 and 443 are currently open and not subjected to the same level of inspection.
I very rarely use BT myself but every now and again it comes in handy for troubleshooting.
04-04-2011 10:15 AM
04-04-2011 10:13 PM
Perversely, I just had to log into Yahoo Mail (pinging at 1300ms, wow!) and dig that out from the email because that was more responsive than going to the portal. The PN My Questions page is still loading, while I've been able to read and delete through 4 days' worth of spam.
When I power the router off and on, for about 30 seconds after the DSL connection comes up, everything works okay. Then it just goes rubbish.
Quote Tracing route to portal.plus.net [212.159.8.2]
2 1233 ms 871 ms 960 ms lo0-central2.thn-ag2.plus.net [195.166.128.230]
3 685 ms 1071 ms 1333 ms gi1-14-221.thn-gw1.plus.net [84.92.6.200]
4 1716 ms 1425 ms 1273 ms po6.ptn-gw01.plus.net [212.159.1.137]
6 * 1028 ms 1263 ms if25.pih-lb03.plus.net [212.159.0.17]
7 670 ms 593 ms 933 ms portal.plus.net [212.159.8.2]
05-04-2011 11:15 AM
I've just done some investigating and your current IP profile is 135k, this has been caused by the number of disconnections as you can see from the graph below. I would firstly have a look at our support pages for dropping connection and if that doesn't help then either raise a fault or call our support center on 08451 400 200
Jojo
