Grabit download speed (help)
- Grabit download speed (help)
Re: Grabit download speed (help)
30-06-2009 12:48 PM
@bktadpoles - On the off chance that I've been looking at the wrong account, could you possibly PM me with your Plusnet username?
30-06-2009 5:16 PM
System Up Time 95:58:54
IAn
03-07-2009 11:23 PM
During the unthrottled time (midnight to midday) I can get up to 800KB/s (Thats K Bytes)
During the throttled time (the rest) it is not worth bothering.
This is using astraweb.
21-07-2009 9:11 AM
Strangely, when Grabit is reading the headers it seems to achieve a vastly better speed, but binary downloads (as you say) suck!
If anyone does manage to get binary downloads to run at sensible speeds than I sould be interested to see how they do it (without using Astraweb - that's cheating!!!! )
The obvious solution is for PlusNet to increase the parallel connections on their server from 4 to 32. That would solve all the problems. I don't know the intricacies of News Server setup, but it may be possible to have 32 during the night and 4 at peak periods. What about it PlusNet techies........
21-07-2009 10:23 AM
As Plusnet servers are supposed to be text only, 4 connections should be perfectly adequate.
21-07-2009 10:29 AM
Quote from: Bob Our news service is *not* intended for binary use. That's been the case for a number of years now. Having said that some maintenance work we carried out a short while ago had the undesired effect of opening up binary access to Plusnet users (whereas it should only really be available for Metronet and Madasafish customers).
We've a communications piece to do before it can happen but things will not stay like this for much longer and binary access will be removed again before too long.
I guess the posting I linked above was the the communications piece he was referring to.
21-07-2009 11:41 AM
21-07-2009 12:19 PM
21-07-2009 12:51 PM
Quote from: short47 I take it therefore that this proposed reduction in service will be accompanied by a reduction in monthly charge??...... No I thought not.
Much of what you want may be available via bittorrent - use of encryption may help here.
Failing that, if you can find a web site, wget may be of use...
21-07-2009 1:13 PM
So are you saying you signed up for the service before spring 2006 when binary usenet groups were officially withdrawn from the Plusnet server?
21-07-2009 1:21 PM
21-07-2009 1:23 PM
You can use Binary Newsgroups as a customer of Plusnet.
We merely do not supply our own. I persnally have a subscription with Giganews and I know a number of our customers do the same.
21-07-2009 1:29 PM
Quote from: short47 Nowhere, when I signed up, did it say that binary newsgroups were not supported.
And nowhere did it say that Plusnet provided a binary usenet server. I believe the number of ISPs that provide that service nowadays is diminishing rapidly.
http://www.news.astraweb.com/ have some pretty good plans. Retention is currently 340 days (heading to 365) and I've always found completion to be very good.
21-07-2009 2:54 PM
Quote from: jelv http://www.news.astraweb.com/ have some pretty good plans. Retention is currently 340 days (heading to 365) and I've always found completion to be very good.
Indeed they do & very good they are too. But I would advise short47 to start with a cheap or short term subscription until he finds how it works with his Plusnet account. The 1st page of this thread raises a common complaint. Binary usenet traffic is the first to be restricted & restricted very hard as soon as the network comes under any strain, as it does for substantial periods of every day. Just how hard depends on the package you are on - for some it's unusable pretty much all the time (& Plusnet make no secret of that - they say so in the product description) & on some others it's only really usable in the wee small hours of the morning.
It's not uncommon to see speed complaints about usenet when all other protocols are running fine on the same connection & on accounts that should, on the face of it, provide a reasonable usenet speed.
21-07-2009 2:56 PM
