Grabit download speed (help)
- Re: Grabit download speed (help)
29-06-2009 4:49 PM
I am not in the least bit technical so please keep it simple.
I used to be with Zen and moved to plusnet after they discontinued the binary service. When with Zen I always had 8meg download speed. Since moving to plusnet i cannot get anything over 54kbps. Not even a Meg, anytime day or night. Can anyone help me PLEASE!.
Many thanks
29-06-2009 5:36 PM
http://www.kitz.co.uk/adsl/frogstats.php
Could you also check your PN profile at https://portal.plus.net/my.html?action=data_transfer_speed (don't post the last 4 digits of your phone number).
Depending on your package there will be traffic shaping, but it should be less severe outside peak hours.
Have a read and select your package - http://www.kitz.co.uk/isp/plusnet_shaping.htm
29-06-2009 7:35 PM
29-06-2009 8:00 PM
i am on the unlimited package. am am just about to try some of the suggestions. i will let you know how i get on.
29-06-2009 8:08 PM
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 1714775 2634784 0 454 9290 95:55:58
LAN 10M/100M 1232130 706836 0 4546 214 95:58:52
WLAN 11M/54M 1422181 1029473 0 4866 334 95:58:50
ADSL Link Downstream Upstream
Connection Speed 8128 kbps 448 kbps
Line Attenuation 21.0 db 11.0 db
Noise Margin 9.5 db 25.0 db
Telephone number:
0127876****
Phone exchange:
Estimated line speed:
8 Mbps - Checked on 2009-05-24 11:06:50
Current line speed:
7150
hope this is the right information?
29-06-2009 8:11 PM
using a netgear router DG834pn
29-06-2009 8:13 PM
also have you tried downloading after midnight?
29-06-2009 8:17 PM
broadband speed test know is 6019kbps with a upload of 374kbps.
i am on grabit now and the download speed is 56.8kbps
arghhhhhhhhhhhh
29-06-2009 8:58 PM
It goes to the back of the priority queue
Binary usenet is even more frowned on - their usenet offering doesn't even have it.
Your best bet seems to be bit torrent - if it suits your wants.
BTW You were tricked into that "unlimited" broadband.
Usage is unlimited
Speed can be very limited
Yet another sucker signed up for 18 months
29-06-2009 10:09 PM
That wasn't very nice was it? Calling a new customer a sucker? behave yourself, or I'll be feeling your collar shortly.
29-06-2009 10:41 PM
29-06-2009 11:35 PM
someone must have some idea as to another way of getting the binarys a lot quicker than 54kbps. if not with grabit with someone else.
30-06-2009 1:16 AM
http://www.plus.net/support/broadband/quality_broadband/load.shtml should make for an interesting read.
It's worth putting your package details into http://www.kitz.co.uk/isp/plusnet_shaping.htm - this shows the
absolute maximum performance you can ever achieve with your package.
30-06-2009 9:02 AM
Welcome to the forum.
You should be getting considerably faster usenet speeds given the product that you have signed up for. You are not on the unlimited package - you have signed up for Plusnet Pro which carries a 15GB peak usage allowance and prioritises all traffic at all times of the day.
Could you possibly show us the result of a normal speedtest over at http://mybroadbandspeed.co.uk
30-06-2009 12:46 PM
