Got sorted back in May.... now speeds worse than ever?
In May, with the help of posters here I managed to improve my speed to around 5-6 mbps from a lowly 3.
The previous thread is http://community.plus.net/forum/index.php/topic,86183.0.html.
Today I did a speedtest at Speedtest.net and got this
I took my router stats which are as below
Any idea what's happening?
5 REPLIES 5
Re: Got sorted back in May.... now speeds worse than ever?
I've had a quick look in the exchange and on all of our systems and I can't see anything obvious that's causing the problem. Please report this the the Faults Team who can perform more in depth testing for you.
Fixes: 10
As your router has been up for 80+ days a reboot is worth a try - however I'd leave it until tomorrow between 10am and 3pm as that's the best time to do it.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
I reported the fault, went through the questions......
This is what I have tonight.
I just tried my wife's laptop and it's getting 5.8 MBPS. What might be slowing my PC down?
This is embarrassing......
I just "jiggled" the wi-fi dongle about a bit and now I get this.....
Crazy
i find it a good idea to disable and enable the wifi dongle or wifi card every now and then Wink
