Google Nexus connection
JustinW
Hi
My Google Nexus has worked wirelessly at home fine up until now. For some reason it won't link to the router - message being "secured with WPA/WPA2" and asking for password which I don't think I have. The tablet works absolutely fine with other wireless networks but not just at home. Laptop etc is working fine on same network.
Any help gratefully received.
7 REPLIES 7
Re: Google Nexus connection
Which router are you using?
It's not secure to run a wireless network without some form of protection.
DaveyH
All Star
Fixes: 10
If it's the PN supplied Technicolor router the default wifi password is printed on the label on the bottom of the router, or on the plastic card that comes in the box.
Edzashed
My wife uses the nexus 7 just use the wps button on the nexus to link with router  Cool
DaveyH
All Star
Fixes: 10
WPS is considered insecure. I disable it.
Fixes: 4
My wife's Nexus works OK on our network. She just enters the network password as normal which uses WPA2 encryption. I always change the supplied password to something I can remember, same with the SSID.
JustinW
The router is a  Thomson TG585 v8
Fixes: 80
All the info on default passwords etc for PlusNet supplied TG585's is here http://www.plus.net/support/broadband/hardware/thomson-585-faqs-and-troubleshooting.shtml
Hope that helps
