Good speed, but sites hanging.
- Good speed, but sites hanging.
11-09-2017 8:52 AM
Hello,
I have had my new Plusnet BB two weeks. I'm getting excellent speeds but I'm sure the service keeps dropping out. Twitter and facebook just hang for ages, and videos are constantly buffering.
I had a slower service with my previous provider, but these issues didn't happen.
Any help would be appreciated.
I have tried the chat function with your support team, but it always appears as offline. Your telephone support was reporting a 30 minute wait time.
Thanks!
Re: Good speed, but sites hanging.
12-09-2017 2:17 PM
13-09-2017 8:46 AM
I have a mac, two ipads, PS4, and a TV connected to the router at the moment. The issue appears to be just with the ipads.
13-09-2017 12:15 PM
13-09-2017 12:36 PM
Yeah, everything's on wifi.
11-11-2017 11:06 PM
13-11-2017 11:16 AM
Given that this is all over wifi there are two potential causes...
- WiFi channel swapping
- WiFi band swapping
Where a router is set to AUTO-SELECT the wifi channel, it will constantly monitor the wifi spectrum and if it determines that the current channel in use does not "look good" it will swap to a "better" channel. If can then take a moment or two for the attached devices to follow the channel change. In some cases (I've seen it with printers) they do not follow the channel change at all.
The best resolution for this issue is to make the router stick on the same channel - choose one of 1, 6, 11 - the use of just these channels reduces the potential for WiFi APs to operate with over-lapping channels - co-channel is much less of an issue. inSSIDer is a useful tool for inspecting the use of the WiFi spectrum in your locality.
Some devices (particularly iDevices) get confused in situations where 2.4GHz and 5GHz WiFi bands use the same SSID - they flip-flop between the two and the flip-flop takes time. Consider changing the WiFi router settings so that the 5GHz band has a different SSID name (put '5' on the end) or turn off 5GHz.
