Gone downhill the past 2 weeks
- Gone downhill the past 2 weeks
Re: Gone downhill the past 2 weeks
01-03-2013 9:47 AM
01-03-2013 9:50 AM
Might be worth changing gateways and seeing if that helps. Disconnect/reconnect from the router admin page - don't turn your router off/on.
01-03-2013 9:52 AM
How do we change this?
01-03-2013 9:55 AM
Btw, I am on ptw-ag02 and not suffering any problems.
01-03-2013 10:01 AM
01-03-2013 10:08 AM
01-03-2013 10:11 AM
01-03-2013 10:17 AM
01-03-2013 10:22 AM
I did the reset up of my gateway on the router ie start fresh so now back online.
Now it says
Actual Speed [Mbps]: 113
Was a bit quicker to get on here too but early days yet
01-03-2013 10:25 AM
Actual Speed [Mbps]: 78
What is this for anyway
01-03-2013 10:26 AM
01-03-2013 11:25 AM
Your profile looks like it should be back up at 7000 across our side and BTs so not sure what's going on with the speed there. What's a BT speed test reporting?
01-03-2013 11:39 AM
Download 6.30
Upload 0.17
Ping 60
Speedtest.net reported what i have posted up above... a few post above.
It was the browsing speed that was slow earlier might a bit ok at the moment.
01-03-2013 12:04 PM
01-03-2013 12:22 PM
Download speedachieved during the test was - 6.64 Mbps
For your connection, the acceptable range of speeds is 0.6 Mbps-7.15 Mbps.
Additional Information:
Your DSL Connection Rate :8.13 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 7 Mbps
