Glacially slow speeds
- Glacially slow speeds
- « Previous
- Next »
Re: Glacially slow speeds
15-04-2013 11:21 AM
You are on ADSL2+ but your connection is banded between 7168 and 14336 - unfortunately as things stand that won't be changed as you're not syncing at the top end of the banding.
Is the router in the master socket and everything else throughout the premises that's plugged in done so through a filter?
We're not seeing many disconnections but I suspect there's a few errors on the line that are preventing it from connecting any faster.
15-04-2013 8:10 PM
16-04-2013 2:34 PM
What are your reasons for saying that? I did actually check andyp's line stats in BTs monitoring systems to advise of the above information, and am not in the habit of lying to customers whether in public or not.
EDIT: Apologies, didn't mean that to come across as it did. The information I posted came from BTs reporting systems which do tally up with what we're seeing on the line, I'd be very surprised indeed if they were incorrect.
16-04-2013 8:02 PM
EDIT:
Download speed achieved during the test was - 6.8 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 12.65 Mbps
17-04-2013 10:03 AM
EDIT: Consistency check comes back fine so profiles are matching across the exchange equipment.
17-04-2013 6:51 PM
18-04-2013 10:25 AM
Not a lot really, though it's looking like you're now syncing at the top of the banding. If that keeps up as is and we don't see many disconnections I suspect an SNR reset might well do very good things, I'll check again tomorrow.
19-04-2013 8:22 AM
Download speedachieved during the test was - 11.96 Mbps
Upload speed achieved during the test was - 1.06Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.83 Mbps
Router statistics:
ADSL Link Downstream Upstream
Link Rate 14335 Kbps 1240 Kbps
Line Attenuation 16.5 dB 7.7 dB
Noise Margin 15.6 dB 6.2 dB
19-04-2013 11:36 AM
19-04-2013 4:08 PM
19-04-2013 4:36 PM
Give's a shout if there's anything else we can help with.
- « Previous
- Next »
