Give me a break
- Give me a break
Give me a break
23-04-2010 11:29 PM
Re: Give me a break
26-04-2010 9:06 PM
System Error Image not loaded
Performance Tester is unable to run the speed test for your telephone number:01248XXXX. Please check that it is the correct telephone number for your service. Did you follow all the instructions given on the website, before initiating the speed test. If not, then please follow all the instructions carefully and try to run the test again.If you believe it is the correct number for your service and you have followed all the instructions then please ask your Service Provider whether you can use Performance Tester to test your Broadband speed. If yes, then ask him for the Service ID of your broadband connection and try again with this Service ID along with your Telephone Number. If this problem persists, raise the issue with your service provider.
adie:green removed persoanl information, please remember this is an open forum and posts can be read by anyone.
Re: Give me a break
27-04-2010 8:21 AM
Re: Give me a break
27-04-2010 10:50 AM
Are you still seeing the same issue here? I have just checked your account again and ran a few tests, I can't see anything that would point to this being caused by a fault. If you're still having no joy with the BT speed tester try giving www.mybroadbandspeed.co.uk a go.
Re: Give me a break
27-04-2010 1:44 PM
Re: Give me a break
27-04-2010 1:47 PM
Re: Give me a break
27-04-2010 2:06 PM
Re: Give me a break
27-04-2010 3:19 PM
Re: Give me a break
27-04-2010 5:08 PM
Re: Give me a break
29-04-2010 10:44 PM
Re: Give me a break
30-04-2010 11:40 AM
Cheers for letting us know. Its not really up to us to advise on computer issues but it sounds like you may want to try re-installing the java client. If its still bothering you see if you can get a screengrab of the error.
Re: Give me a break
30-04-2010 1:18 PM
Re: Give me a break
04-05-2010 11:58 AM
