Gigabit router to replace Technicolour TG582n
- Re: Gigabit router to replace Technicolour TG582n
22-07-2014 10:39 AM
I am building a new home NAS and I realised that the switch on the technicolour is only 100MB - I assume the only way to get around this is to replace it with a better router - does anyone have any recommendations? gigabit wifi would be nice too but I am mostly concerned about the switch part I guess. Thanks
22-07-2014 10:41 AM
I don't believe gigabit wifi is a thing (not in residential routers anyway) but I use a TP-LINK WDR4900 which has gigabit ports and I believe the headline wifi speeds are 950mbps, depending on your other hardware of course, but I've had no issues with throughput on this router wired or wireless.
22-07-2014 10:55 AM
I'd recommend the TP-Link WDR3600 (it's what I have) it has simultaneous 2.4Gz and 5Ghz WiFI banding, or if your hardware supports it, it can combine the two channels to give faster speeds. It's a very customisable router, and comes in around the £50 mark.
22-07-2014 11:19 AM
An example http://www.ebuyer.com/411321-netgear-gs205-5-port-gigabit-ethernet-switch-gs205-100uks
22-07-2014 11:31 AM
Also pwatson - can I just plugin that switch to the BT modem or would it need setting? I assume it would be pointless to connect it to the technicolour as the output from that is 100mbit.
22-07-2014 11:32 AM
22-07-2014 11:57 AM
Quote from: kkar Also pwatson - can I just plugin that switch to the BT modem or would it need setting? I assume it would be pointless to connect it to the technicolour as the output from that is 100mbit.
It's an extra box - Leave you router plugged into the modem and plug a LAN port of the router into the switch. Connect your devices to the switch instead of the router.
22-07-2014 12:15 PM
Traffic between the 2 devices on the switch shouldn't need to go via the router.
22-07-2014 9:18 PM
Quote from: pwatson
The LAN port? can you please tell me what one that is? here is the picture: http://community.plus.net/library/hardware/tg582n-information-and-specifications/
The yellow ports are all 100mbit no? so how would the switch take advantage of this?!
22-07-2014 9:26 PM
