Get BT to change my exchange...
- Get BT to change my exchange...
11-03-2009 12:54 PM
I have been hunting around for an answer to this for a while, and short of getting some half hearted salesy response from a BT call center part-timer, I thought I'd ask it here.
How do I get BT to change which exchange I'm connected to, and would this give me better, faster broadband? I currently get a sync speed of around 1900k and a throughput of about 1500-1600k, but I'm greedy and want more!
I currently live in Swindon (SN3 2NP, http://www.samknows.com/broadband/exchangelist.php?filter_field=cou.name&filter_value=Swindon), quite a large town with 9 exchanges. My current exchange is called "SWINDON" (SN1 1QT) which is 2.3 miles by car (according to Google) - this gives an estimated line distance of around 3 miles (2.3 * 1/3).
My downstream attenuation is 63, which gives me an estimated line distance of 2.79 miles (4.5km from http://www.kitz.co.uk), so say around 2.9 miles as an average.
There aren't are "closer" exchanges, but in changing my current exchange, would I get a better quality copper cable than I currently have, and newer or different equipment in the exchange? Would BT charge the earth for this, or is there a way to get it for free? If I get a new phone line, can I choose the exchange it gets connected to?
Other than that, I have Cat6 cable my side of the NTE5 master socket for about 5 meters to the modem, a range of expensive filters available (currently using the one that gives the fastest speed), and a Netgear DG834PN modem/router.
All in all from when I moved in two years ago, I've managed to scrape about 600k of improvement from my first cheap dodgy router and miles of extention cable.
Thanks in advance!
Re: Get BT to change my exchange...
11-03-2009 1:04 PM
You could pay them several thousands of pounds to reroute your cabling. They *will not* do it otherwise.
I know speeds are a pain, but unfortunately it's exactly how broadband works and there really isn't any way of moving you closer to the exchange or changing your wiring routing without you paying for it.
11-03-2009 1:45 PM
Kinda what I guessed, just needed some confirmation...
Hows about getting a new line - can I choose what exchange it comes from?
11-03-2009 1:46 PM
Not all the wiring to the exchange.
11-03-2009 2:12 PM
With this new ADSL2 stuff, do you know what would be the likely increase in speed I would get? or do you need some details?
My modem is already compatible, so I won't need any new hardware...
11-03-2009 2:20 PM
11-03-2009 2:26 PM
either that or
A. Move house
B. Live in the broom cupboard at work
C. Virgin media (not after my friends experience!)
11-03-2009 2:27 PM
So unless there is another multi-pair cable in your local junction box which goes to another exchange ( I would have thought this unlikely ) you couldn't be connected to another exchange.
11-03-2009 2:36 PM
Phil
11-03-2009 3:03 PM
12-03-2009 1:51 AM
I know that a BT employee living closer to the demarcation line asked to be put on to the closer exchange as I saw the worksheet. Not sure if it was completed as the telephone equipment was from the further exchange with the adsl and the tie pair out on the closer exchange.
12-03-2009 10:35 AM
Quote from: sarahandjohn oh, of course, that would make sense really!
If your downstream attenuation is 63dB ADSL2 iwll not hel much, if at all. See <a href="http://community.plus.net/wp-content/uploads/2008/04/internode-adsl2-distance.jpg">here</a>.
