Get 150N with the WNR1000v3 - Change to Channel 13!!!!!!!!!!!!!!!!!!!!!!
- Re: Get 150N with the WNR1000v3 - Change to Channe...
12-08-2011 1:00 AM
Dick:red Post edited to remove all caps as per forum rules
Message 1 of 8
(2,780 Views)
7 REPLIES 7
Re: GET 150N WITH THE WNR1000v3 - CHANGE TO CHANNEL 13!!!!!!!!!!!!!!!!!!!!!!
12-08-2011 10:33 AM
a) Wut?
b) Stop shouting! Besides being against most forum rules, it's extremely annoying.
Message 2 of 8
(815 Views)
12-08-2011 8:58 PM
1/ Don't be a pedant. 2/ It is 'what' not 'Wut' 3/ It is most forum's rules ie. the rules belonging to a forum or fora.....did you see the irony there, I'm dryer than a biscuit, me!
..............wuh wuh
Anyway, to the point of the reply:-
There are a few posts on the forum relating to peeps having 802.11n capable wireless networks but whom are only able to see 72n in wifi analysers(inSSIder)....I have discovered that by setting the channel manually to 13 it will now span the channels required to give full 150n despite there being other APs nearby, which, when channels; Auto, 1, 6 or 11 are used, will interfere with the signal and restrict the bandwidth to 72n.
Ta daa!
Almost genius level, despite not knowing forum rules and being a gramma/syntax nazi.
Jez
dick:quote
Ta daa!
Jez
dick:quote
Message 3 of 8
(815 Views)
Re: Get 150N with the WNR1000v3 - Change to Channel 13!!!!!!!!!!!!!!!!!!!!!!
13-08-2011 2:22 PM
Hi
Your point is?
54g will cope with your speed.
Derek
Your point is?
Derek
Message 4 of 8
(815 Views)
13-08-2011 4:04 PM
No they would not the maximum speed you likely to see with 54g is 17mbps. Most users did not know the limitions of 54g until they went to fibre. The theoretical maximum speed is approximately 27mbps (54/2) but this would never be achieved.
Message 5 of 8
(815 Views)
13-08-2011 7:08 PM
Hi
@itsme
Well I use my friends Fibre Broadband, for large downloads. We quite often achieve , via speed tests and using Bitmeter monitoring, speeds of over 32 Mbps on his wireless system.
The connection on the taskbar lists the connection as - Excellent 54 Mbps. For info router is a Linksys WRT54GS
Derek
@itsme
Derek
Message 6 of 8
(815 Views)
13-08-2011 9:07 PM
Quote from: Stumpy21 Hi
Your point is?
Derek
Having read quite a bit about wireless networks it is apparent that one should only expect around half of the stated bandwidth reliably. I am given to understand, and it is now my experience having just upgraded from 54g, that moving up to 72n would give me a significant improvement in my throughput and further improvement when I got 150n to work properly. 54g will not cope with 40mbps very well and I suggest that you will not find anything to support your claim.
Jez
Message 7 of 8
(815 Views)
14-08-2011 2:04 PM
Quote from: Stumpy21 Well I use my friends Fibre Broadband, for large downloads. We quite often achieve , via speed tests and using Bitmeter monitoring, speeds of over 32 Mbps on his wireless system.
I would say a download speed of 32Mbps is impossible, are you sure that the Bitmeter is not measuring both downstream and upstream?
Message 8 of 8
(815 Views)
