Gaming problems, is it down to my Internet or is it down to the 2704n router
- Gaming problems, is it down to my Internet or is i...
Re: Gaming problems, is it down to my Internet or is it down to the 2704n router
29-02-2016 2:49 PM
Quote I just want a stable connection
Turning interleaving off is likely to reduce the stability on a line, not increase it.
Are you still connected via a wired connection since the SNR increase towards the back end of last week? I'd be interested to know how the line is performing over an ethernet connection now.
29-02-2016 2:52 PM
Alex, you are on ADSL2+ also known as 21CN.
29-02-2016 2:57 PM
Quote the ping time virtually halved to 17/18ms depending on which Gateway I was on.
Again though, a ping around 35ms is not a problem in the slightest.
Quote He is talking about stability from the latency point of view.
Most likely, but the line isn't without disconnections:
The most recent set of ping results are absolutely fine, if there is 'significant lag' still showing when the pings are at those it's unlikely to be the ping time causing it.
29-02-2016 3:10 PM
@Anotherone I really ain't sure if I am on adsl or adsl2+ I have asked but not got a reply on what I am on, I looked up my exchange and apparently it does support adsl2+ but as to whether I am on this or not I have no clue, although I suspect I am on adsl and not adsl2+
29-02-2016 3:16 PM
29-02-2016 3:17 PM
Can you please check if those are just PPP drops or are there drops in the sync?
29-02-2016 3:20 PM
29-02-2016 3:27 PM
29-02-2016 3:35 PM
Quote from: Anotherone @Chris,
Not really, the only information we get is the number of initialisations in an hour, min, max and average which doesn't really help.
29-02-2016 3:37 PM
Alex, ah right, that will certainly account for a fair number of those drops. Let me just check on some modem/router pages for you to look at.
29-02-2016 3:42 PM
I have done port forwarding on my xbox to get an open nat but for some reason I still have nat issues.
29-02-2016 3:49 PM
29-02-2016 3:53 PM
Indicative Line Quality: A
Initialisations MIN: 0 | MAX: 5 | AVG: 1 (Times in an hour)
29-02-2016 4:03 PM
29-02-2016 4:06 PM
