Further Speed Issue
- Further Speed Issue
Further Speed Issue
16-11-2011 1:41 PM
Hi
I recently had a speed issue with my connection speed and raised a previous thread in relation to this. http://community.plus.net/forum/index.php/topic,99445.msg842264.html#msg842264
This issue was resolved through changing my line to ADSL2+ which did fix this, however over the last few days my connection speed has dropped to what I previously was receiving (AROUND 2000 KPS)
Have there been any recent issue that could have caused this ? I have checked my modem and everything appears to be ok from that side of things.
Cressa
Cressa
Message 1 of 4
(957 Views)
3 REPLIES 3
Re: Further Speed Issue
16-11-2011 1:56 PM
I've just checked your account and ran a line test, whereas I can't see anything obvious from that your connection logs seem to indicate that disconnections might be a factor in the drop in speeds. I'm going to advise that you raise a fault with us: https://portal.plus.net/apps/kbdfaults feel free to come back to me for further assistance after you've done that though.
Message 2 of 4
(452 Views)
16-11-2011 9:59 PM
Hi
After doing some further testing tonight it appears that the issue is with my router rather than the line.
Connecting my PC directly to my modem produces the expected speeds so somehow my router must be throttling my connection. Had a look at my router settings tonight and cant see anything obvious why it would be doing this. Im using a Netgear G54 (WRG614) wireless router if anyone has any ideas
Message 3 of 4
(452 Views)
17-11-2011 10:19 AM
I'm not familiar with that particular model but obviously do start with checking the wireless settings, perhaps try manually re-setting which channel is being used. Also a factory reset may be a good idea.
Message 4 of 4
(452 Views)
