Full Router Settings?
- Re: Full Router Settings?
11-01-2011 3:05 PM
I joined PlusNet last week, using a Draytec Vigor 2800 router.
The PlusNet Connection Settings web page says the following:
Broadband Username/Login name username@plusdsl.net
Connection Type / Encapsulation PPPoA /PPP over ATM
Password The password you use to log in to this website
Virtual Path Identifier (VPI) 0
Virtual Channel Identifier (VCI) 38
Multiplexing method VC Based / VCMUX / VC-Multiplexing
However, my router has additional settings, in particular:
Modulation Mode:
T.1413
G.Lite
G.DMT
ADSL2 Auto(G.992.3)
ADSL2 annex M
ADSL2+ Auto(G.992.5)
ADSL2+ annex M
Multimode
When setting up my router I found that G.DMT worked, so I left it alone. However, I think that this setting may not be optimum.
In addition, I'm getting a new DrayTek Vigor 2710 router in the next few days, and this supports:
ANSI T1.413 Issue2
ITU-T G.992.1 G.dmt (ADSL)
ITU-T G.992.2 G.lite
ITU-T G.992.3 ADSL2
ITU-T G.992.5 ADSL2+
Annex L (READSL)
Annex M
What is the optimum setting for PlusNet, and what effect will changing it have on Dynamic Line Management?
11-01-2011 3:18 PM
G.DMT or G992.1 is appropriate for your 20cn connection.
Jojo
11-01-2011 3:19 PM
Quote from: Joanne HI nigelmercier,
Jojo
Hi Jojo,
Could you explain the difference?
Also, despite using the DNS settings below:
Primary DNS: 212.159.13.49
Secondary DNS: 212.159.13.50
my router ends up with:
Primary DNS: 212.159.6.9
Secondary DNS: 212.159.6.10
What is going on here?
Nigel
11-01-2011 3:29 PM
All four of the DNS IP addresses point to the same set of load balanced servers so there is nothing to worry about there either.
11-01-2011 3:35 PM
Quote from: jelv One is spelt G, D, M, T and the other is G, 9, 9, 2, 1 Apart from that they are the same (it's just different names for the same standard).
I'm sure I read somewhere on this forum to use G.992.5 - is this not the case?
11-01-2011 4:11 PM
According to Jojo's post you are still on 20CN.
12-01-2011 11:14 AM
dick:quote
12-01-2011 12:28 PM
Quote from: nigelmercier I wonder how she knows?
Because we're your supplier I can see what we have you provisioned on.
Jojo
12-01-2011 12:53 PM
So this is related to my BT exchange? Any idea when it will go 21CN?
jim:quote
12-01-2011 1:19 PM
Yes, this is the equipment that is set up at the exchange. Your exchange does not show a date for upgrade to 21cn I'm afraid.
Jojo
03-03-2011 3:43 PM
Could I suggest that recommended modulation settings (in order of preference) be added to the connection details page please?
I stumbled across these settings on my modem and found that some give 10%+ better synch speed than others... which on a very slow line (due to grotty BT copper cables) ris eally worth the difference!!
I have the options:-
Quote MMODE
T1413
GDMT
GLITE
ADSL2
ADSL2Plus
MMODE & GLITE give me about 1200 kbs, T1413 & GDMT give me a stonking 1376kbs. On MMODE this can sink down to 120kbs. Having found this thread and changed to GDMT I'll now wait to see what (if any) decay I get with the different modulation.
03-03-2011 4:01 PM
03-03-2011 4:47 PM
04-03-2011 10:12 AM
Thank you for the information.
Now that I understand what MMODE does, I've set it back to that and bounced the link. I was somewhat happy to see the link still reporting 1376 this morning... but even happier to see it bounce up to 1408 after the change which is surprising given that the modulation type has not changed. I've also found the report page for the modulation - it shows GDMT. Therefore it seems starnge that yesterday it persistently reported a lower spedd on MMODE. Now I know what I'm looking for I'll keep an eye on the auto selected modultaion type.
Note to Jojo - Just in case you were tempted to go digging, reference to line speed is not in respect of the account linked to this forum identity, but in respect to the IP address of this posting.
04-03-2011 10:20 AM
