Fttc Unlimited sync at 60mbps
- Fttc Unlimited sync at 60mbps
17-05-2013 5:59 AM
First time posting here, any help would be greatly appreciated.
Just moved over to Plusnet ffc Unlimited from Vivaciti, where i was on fttc 40/10. On sign up my speed estimates were 76mbps down and 20 up.
Since the moment my service went live I have been getting the following speedtest results.
Line sync speed 60mbps down and 20mbps up. It makes no difference what i do my line will not sync above 60mbps. A Bt engineer came yesterday and said no problems found, he did however upgrade my modem and supposedly reset the DLM.
It seems to me that a limit is in place somewhere telling my line to sync at only 60mbps. My throughput at 60 is consistently around 58mbps.
Again any help would save me from going crazy as Im sure something is wrong somewhere.
Many thanks.
Re: Fttc Unlimited sync at 60mbps
17-05-2013 9:21 AM
I've just checked your account, the speed profile on our systems is set correctly and I'm sure the engineer and our faults guys will have checked everything relevant on the supplier side of things.
I'll update the fault ticket to link back to what you've mentioned here to make sure the faults guys are aware of what you've mentioned.
Keep us posted as to how things progress with this.
Adam
17-05-2013 9:32 AM
There must be someone between Bt and plusnet that would
Be able to tell my why my line sync is low. Maybe there is no faults but then surely if not I would be seeing higher sync speeds.
Many thanks
17-05-2013 9:41 AM
Do you know how far you are from the cabinet?
Do you have any additional sockets and if so ho are they wired into the master
Is the OR modem plugged into the top of VDSL2 faceplate in the master socket
17-05-2013 9:42 AM
17-05-2013 12:08 PM
Cheers
17-05-2013 1:51 PM
If you put your phone number in at the top of the results it will say which cabinet you are connected to. As to finding the cabinet its a walk around the neightbourhood as the number is vivisble on the outside of the cabinets. I did a quick street view on google map to locate some potential candidates first
17-05-2013 2:05 PM
I wish you better luck than what I have had.
17-05-2013 4:24 PM
I have established that I'm 160 meters from the cabinet, not sure if that's far in terms of signal loss.
@ cwaite. to be honest if I had been told that's the max I can get then I could accept, but I have a reply from one of plusnets techs saying there is a prob and the line is syncing low. Problems can be fixed in my opinion but nobody seems to know how!! Ill have a read of your thread when I get a mo.
Cheers for help everyone
17-05-2013 4:57 PM
I'm 400-450m from my cabinet (following the route of my line from manhole to manhole) and get around a 60Mb/s sync. (and I don't think I have a particularly great line.)
17-05-2013 5:09 PM
My ip profile has been at 60mbps since activation day and I get 59mbps throughput. Its just very frustrating that as an end user we cant do more. 59mbps is hardly slow and I should be grateful but its a fair way off my estimate of 76mbps. Having read the engineers notes it has reported that line is syncing low with errors, then BT arrive and say no problems. Hopefully Plusnet will get to the bottom of this and "Do me proud" as their slogan would suggest.
Many thanks.
17-05-2013 5:13 PM
Sorry just seen your reply whilst I was posting. If its synching low with errors why did the 2nd engineer not investigate further? Mine was low and 2nd engineer said yeah its got some errors. He ripped out the old wiring (its was running on internal wirng fit for adsl but apparantly Not good enough for vdsl2) and fitted new master and wiring. Synch went from low 50s to 80.
17-05-2013 5:36 PM
hi ive only had one engineer call, he said he could find no prob. He updated my modem though and supposedly reset the DLM. No change what so ever though.It was the Plusnet tech that said it was syncing low with errors on his report.
