Frequent Drop outs Red LED
Hi all, I've had a very good service for the past year, Good speed and good quality with only a couple of drops in connection in that time.
Now I am seeing the dreaded red LED on the front of my router quite often. As soon as I see the red LED my internet goes. This is happening more and more frequently.
In fact in the past 2 hours it has dropped 5 times.
To recap:
Internet dies-
Look at router, Red LED
Leave it for 2-3 mins
Comes back on all fine.....
The LEDs are normally green and only turn red when when it connection drops.
I have 'Asked a question' thing but I thought i would come and ask here while I wait.
Ive not changed any of my setup since install a year ago.
14 REPLIES 14
Re: Frequent Drop outs Red LED
It's has now intact gone off as of approx 21:45 and will not come back on. I am using my phone.
can you plug the router into the test socket
I just checked. I can't because the socket is the type with the built in filter.  I've turned off the modem and router a couple of time to see if that fixed it but it didn't.
Within the router it says Link status Connecting...
is it anything like
Or
Yes. The second one.
If you unscrew the bottom half of the faceplate you should see the test socket, plug the router into the test socket
I was aware of the test socket but as the modem connects directly to the socket via the smaller connector I am unable to plug it inyo the test socket without a filter. Do you know what I mean?
I will have a search for a filter.
If i use the cable from my telephone? Will that work?
I can confirm that it is a problem with the router [TG582n].
I setup a direct connection with the modem and that was fine.
I setup a conventional connection with a different router I have borrowed and that is fine too.
I have notified PN and updated the ticket accordantly.
I presume they will send out a replacement?
Thanks.
Hi, looks like that's already been arranged from checking the tickets on your account? The replacement should be with you within a couple of days, hope it sorts things out.
Angry
Received the router today.
Set it up and after about an hour got the dreaded red light again.... Not very happy
Can any staff see to this please. I cant get anything done. It is going off every 5-10 mins!
#80386064
Sorry to hear that, I can see you've raised a fault - our team will be back to you as soon as they've been able to get everything tested.
Now it's completely gone off. No direct connection either.
