Flipping speed
- Re: Flipping speed
Flipping speed
20-05-2011 11:53 AM
I am having problems with speed and the problem seems to be becoming more frequent. I may not be able to respond to any answer you put up online as I can't get online at the moment due to this problem (I am sending from the library).
On the 12th,16th, 17th,18th, 19th and today the speed has been flipping between 1 MBPS and 65 MBPS. On the 16th this was an issue between 16.55 and 17.46, on 17th between 23.54 and 00.58 and today from 09.30.
I am trying to submit coursework and do coursework at the moment so this is an absolute pain.
Can you have a look at this for me?
How soon can I leave my contract?
B
[Moderator's note by Jim (Oldjim) personal identification information removed as it isn't needed ]
Re: Flipping speed
20-05-2011 12:57 PM
Quote n the 12th,16th, 17th,18th, 19th and today the speed has been flipping between 1 MBPS and 65 MBPS.
This sounds like a wireless connection as your broadband isn't provided at 65MBPS. Have you tried connecting to your router with an ethernet cable (we supplied one with the router) and testing the speed after this?
Re: Flipping speed
21-05-2011 10:44 AM
B
Re: Flipping speed
21-05-2011 11:21 AM
Re: Flipping speed
22-05-2011 11:22 AM
Re: Flipping speed
24-05-2011 3:38 PM
Re: Flipping speed
24-05-2011 4:48 PM
Before you start going through changing settings, I've noticed that you have an older version of the firmware on the router. I can update this for you which may resolve any wireless issues you have. Let me know when this is convenient to do, as the router will go offline during the process.
Jojo
Re: Flipping speed
29-05-2011 12:18 PM
Thanks,
B.
Re: Flipping speed
30-05-2011 12:21 PM
I'll do it for you tomorrow.
Jojo
Re: Flipping speed
31-05-2011 12:08 PM
That has completed now. Let me know how you get on.
Jojo
Re: Flipping speed
09-06-2011 10:28 PM
I either need you to sort this, clear instructions on how to sort this or a new internet provider. I am pig sick. This saga has been going on for months and months and months. I get up in the morning with a list of jobs to apply for and I have no idea whether the signal is going to allow me to apply or whether I need to travel 35 miles to uni and set up base there or indeed whether I should give up and buy a laptop and sit in a cafe.
I need a job and this crap really isn't helping.
B
Re: Flipping speed
10-06-2011 11:27 AM
If you are using a PC then I assume you are using a wireless adapter? If so, I would suggest you look at troubleshooting that too. You could also use something like inSSIDer which can scan the wireless networks and help you identify the best channel to use. YOu could also use homeplugs or a long ethernet cable to directly wire to the router. I can understand how frustrating it can be but I very much doubt this is a router issue.
Jojo
