Flashing Internet Light
- Re: Flashing Internet Light
28-11-2012 6:13 PM
Should my internet light be flashing on my router or should it be a solid green light I just wondered about this because is this the reason why my connection drops and reconnects from time to time.
Message 1 of 5
(6,686 Views)
4 REPLIES 4
28-11-2012 7:22 PM
Which router?
Message 2 of 5
(5,730 Views)
28-11-2012 7:39 PM
Some router lights flash to indicate data flow. Other routers have lights that do not flash because people worry about a flashing light.
Message 3 of 5
(5,730 Views)
29-11-2012 10:22 AM
Hi valart,
Your connection is disconnecting every 29 minutes;
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13541840793705.png"/><div style="clear:both;"></div>
Are you using one of our supplied routers?
Message 4 of 5
(5,730 Views)
29-11-2012 1:04 PM
That's suggestive of "connect on demand" with a time-out and trigger (either router or connected PC based) at roughly equal intervals.
Phil
Phil
Plusnet FTTC (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
Message 5 of 5
(5,730 Views)
