First Socket No Improvement
- First Socket No Improvement
- « Previous
- 1
- 2
- Next »
Re: First Socket No Improvement
27-04-2011 8:38 PM
I take your point though that if the wire to the router can pick up interference then it's very likely that the plug in extension wire (before the filter) can add to it.
No harm in moving the filter to the front of the extension and removing the one at the end. Anything to improve the connection is worth a try.
28-04-2011 8:49 AM
Ahh, so the router is on the extension. In which case you'd need to try it directly into this socket as nine times out of ten extensions will be the main cause of troublesome connections.
Jojo
28-04-2011 10:04 AM
As somebody already pointed out it seemed worse plugged into that.
28-04-2011 10:13 AM
Looking at your stats from the beginning of the thread it looks like you're banded on 1472Kbps - 3072Kbps so that's why 3072 was the max sync you were getting. Plug it back in there, I'll see if I can get the banding removed and then we can check if the sync has increased.
Jojo
28-04-2011 11:12 AM
28-04-2011 11:25 AM
29-04-2011 10:11 AM
A nearby Telecom van, and its occupant, were happy to remove the unnecessary connections from the main socket (three were connected) for the princely sum of a cup of tea and a biscuit. I still think I was hard done by as it only took all of five seconds.
Any you can see by the SN Margin there has been an improvement. Hopefully the errors will be reduced as well.
Now it's just the waiting game.
Uptime: 0 days, 0:12:56
DSL Type: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 443 / 3,072
Output Power (Up/Down) [dBm]: 13.0 / 0.0
Line Attenuation (Up/Down) [dB]: 23.0 / 42.5
SN Margin (Up/Down) [dB]: 24.5 / 18.5
Loss of Link (Remote): 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 5
HEC Errors (Up/Down): 0 / 4
29-04-2011 10:29 AM
If all goes well you "could" be getting around 8mbps.
29-04-2011 11:45 AM
I remember a few years back when I had a phone problem it was remarked about the old style socket but it was never replaced.
29-04-2011 12:00 PM
29-04-2011 2:22 PM
04-05-2011 9:08 AM
I'll look into getting the banding removed and see how it goes. I'll let you know once it's done.
Jojo
04-05-2011 11:47 AM
Is there anything recommended that I do? Just leave it or is there any time at all that I should disconnect and reconnect?
Uptime: 0 days, 0:13:16
Bandwidth (Up/Down) [kbps/kbps]: 443 / 6,231
SN Margin (Up/Down) [dB]: 25.5 / 8.0
04-05-2011 12:02 PM
Don't change anything. It has been lifted now and your profile is 5000 which I've now applied on our side. You should see the improved speed in the next 15 minutes.
Jojo
04-05-2011 2:23 PM
- « Previous
- 1
- 2
- Next »
