Finding my router password
- Finding my router password
01-07-2012 2:44 PM
Hi
Recently upgraded to fibre with new `Openreach router and a `Netgear` modem. How can I find my router password to allow a friends laptop to use my wireless connection, please.
regards
PE
regards
PE
Message 1 of 4
(879 Views)
3 REPLIES 3
Re: Finding my router password
01-07-2012 2:48 PM
I guess you mean Netgear router and Openreach modem. The default login for the router is user=admin password=password. You ought to change the latter at the first opportunity
Message 2 of 4
(424 Views)
01-07-2012 2:52 PM
PS having logged in you can set the wireless pass phrase to something of your own choice under Setup - Wireless settings at top left.
Message 3 of 4
(424 Views)
06-07-2012 11:08 AM
Thanks David,
Glad you noticed the deliberate error
I had a senior moment-got a bit confused as my previouse router was first in line out of the BT connection box followed by the modem,whearas the new setup has the modem followed by the router..
Have now managed to change my SSID and passphrase.
Regards
Regards
Message 4 of 4
(424 Views)
