Fibre setup - cabling question
- Fibre setup - cabling question
05-08-2012 11:58 AM
My inlaws are still thinking about fibre and as this means having a fibre modem and a seperate router I am trying to work out what goes where. From reading the Plus Net pages I know that a new master socket is installed with 2 outlets, one for phone and one for broadband. My inlaws master socket is in the hallway but there is no power near to it. I see that BT will extend cables, but does this mean moving the whole master socket or can they just extend where the wire goes so that the fibre modem can be put near a plug socket in a different room and still leave the phoen in the hall?
Re: Fibre setup - cabling question
05-08-2012 1:02 PM
However, the engineer who installed our FTTC was more than happy to use our internal wiring to turn one of our extension sockets into our master and then turn the old master into a new extension for us.
Alex
05-08-2012 1:23 PM
a new cable from the junction box outside my house all round the outside and through i Hole i had previously drilled where i needed the socket just ask nicely
05-08-2012 1:38 PM
Has anyone got any pictures of or links to details about the 2 pieces of kit that get installed?
05-08-2012 2:41 PM
my BT box is screwd to the wall where the next to the master socket , and the Netgear router is on my desk next to it
05-08-2012 2:59 PM
Is there a way that they can keep the master socket in the hall then and put both the modem and router upstairs? It just looks like an RJ11 that comes from the master socket to the modem? If they had a longer RJ11 cable would this have a detrimental effect on the speed ?
05-08-2012 3:42 PM
05-08-2012 4:43 PM
thanks
05-08-2012 9:02 PM
Here's another couple of guides, read both parts http://www.clarity.it/telecoms/adsl_faceplate.htm & http://www.clarity.it/telecoms/extensions.htm
Where the guides mention ADSL, it applies equally to FTTC, which is just VDSL, another flavour of ADSL.
Hope they help
05-08-2012 10:48 PM
Your article mentions using certain colours but that was to do with using the RJ 45 into a patch panel. If it is going to have the rj45 plug cut off and just the cable used in the boxes at each end I suppose it doesnt matter which pair we use for adsl or phone does it?
05-08-2012 11:16 PM
You can use this cable internally http://www.clarity.it/xcart/product.php?productid=16192&cat=255&page=1
You don't need plugs on the cable, and it needs to be solid core, which the stuff I linked to should be. If it's multi strand which you may find in an off the shelf network cable with plugs on it won't make a secure connection as the wire is pressed in, and ideally you should get a krone tool if doing it yourself.
Edit: If your buying a long length of Cat5 cable you may find it cheaper elsewhere. Such as here http://www.tlc-direct.co.uk/Products/CACAT5Eslash50.html , I've used Clarity & TLC many a time.
09-08-2012 12:31 PM
- BT will install a new face plate thing where the master socket is.
- I will have already run a solid core cat 5e cable from the office (spare room) to the master socket.
- one pair needs to be connected to the ADSL part of the new master socket
- The ADSL pair needs to be connect to what at the other end in the office - is it an RJ11 or RJ45 socket. I have read a few articles on the net now and both are quoted.
- another pair from the master socket in the cat 5e will be connected to a BT type socket in the office
I have had a look at this extension kit and it gives the option of an RJ11 & BT Socket or also an RJ45 & BT Socket.
Which is the better one to use? I know an RJ11 will fit into an RJ45 socket but will it be loose? I just don't want to order the wrong thing.
09-08-2012 1:28 PM
Might have another friends to do soon, he's only getting 12mb and should be getting more like 18 considering how close he is to the exchange.
09-08-2012 2:23 PM
09-08-2012 7:12 PM
