Fibre line fault - question ID #90614354
- Fibre line fault - question ID #90614354
Re: Fibre line fault - question ID #90614354
01-09-2014 11:52 AM
Quote from: Adam Hi richardc1983,
I'm sorry that the outages came at such a crucial point in the fixing of your fault. Thankfully it seems that the speed hasn't dropped as much as before and it seems that you have re-sync'd a few times and the speeds have come back up so the DLM should be in the process of returning you back to the speeds you were seeing previously although this can take a little time.
Have you seen any further change since flagging this up again on Sunday?
Other than all the errors which are occurring and the advisor said yesterday that this is an unacceptable ammount of errors. Open reach are aupposed to be coming back out today between 8-1 although said I don't need to be at home for this. I haven't noticed an improvement to be fair can you advise if they have done anything yet?
03-09-2014 10:39 AM
Rather than a standard reply please could I have a proper update where you actually look at the account and see that a none appointed task was raised for open reach to attend. The last I heard was "DCoE Colombo House Line test completed on Woosh & was testing in sync at 64.2/20 Mbps but Fail - Upstream ES and SES have exceeded threshold from real time check RRT shows the line is still having Errors in downstream and/or high number of retrains. DLM is still managing the profile down CSE had closed previous action item task with notes as below:- ---- Lift and shift completed to restore corr ect sync speed and c lear HR fault. Pq ok with new ties. LTOK ---- The line was previously testing Fail - Upstream ES and SES have exceeded threshold from real time check The line is still syncing above it's predicted speeds and erroring, DLM yet to stabilise. Action Item slept for another 24hours to allow DLM to manage line before further analysis."
Please advise what is going on the whole service has been very poor so far and I shouldn't have to keep chasing this.
03-09-2014 11:11 AM
It looks as though the engineers have opted to resolve the issue by administering a lift and shift, the results of which we are still waiting for as the DLM was still in play so they had parked the fault for 24 hours in order to wait for this to settle before retesting and then giving us an update on the next steps on resolving the issue.
We appreciate that having a fault is far from the service you expect to be provided with, however we must follow the correct processes with the supplier when managing a fault and at the moment, we are still awaiting further updates. Please accept our apologies for the inconvenience caused during this fault fixing process, you will have an update applied to the support ticket for you as soon as this is made available to us.
By the sounds of of the last update we had, it could well be that the engineer attends the exchange again in order to perform a DLM reset (I'm afraid this cannot be done remotely or at request) if they believe that the stability of the connection is fine. If not then it could well mean that additional works need to be carried out before the reset takes place and you see the speeds lift.
03-09-2014 11:14 AM
That reply is a bit more informative than the previous reply. Can you explain what a lift and shift is?
03-09-2014 11:30 AM
03-09-2014 1:45 PM
The lift and shift is a bit like a total reset of the connection where everything is removed and put back together as if the service was being set up for the first time so eliminates any misconfiguration with the equipment.
With regards to this being done a second time, this may have been done if the engineer attending on the day believed that this hadn't been completed before or if he saw some merit in doing this for a second time.
03-09-2014 5:17 PM
dick:quote
03-09-2014 5:32 PM
I'm afraid there isn't anything present at the moment as the last update from the supplier showed a wait of 24 hours to allow for the DLM to settle before they were due to test again and then provide us with detail of the outcome/next steps.
Given that this should come back to us at some point today/tomorrow, you'll see an update applied to the support ticket as soon as we have had the details passed to us.
In the meantime, I'm sorry about the delay and would hope that you'll see the update and progression of the fault very soon.
04-09-2014 8:21 AM
It's a shame as the attainable rate is 77 so I should be getting that near enough.
05-09-2014 11:28 AM
05-09-2014 12:22 PM
Bearing in mind your line estimate is 60mbps, I've attached a GEA test of your circuit. I've updated the profile on your account to match so you should be getting close to 60mbps now.
Dan
05-09-2014 12:33 PM
BT wholesale estimate 72 so that's what I expect.
05-09-2014 12:37 PM
05-09-2014 12:59 PM
06-09-2014 8:52 AM
This really isnt acceptable that I should have to keep chasing it and I wish someone would take some ownership and pressure OpenReach to carry out whatever repairs are needed. The likelihood of it is that the copper cabling going back to the cabinet needs replacing... they need to stop dragging their heels and crack on with the maintenance work. This might have been acceptable on ADSL but not on Fibre.
