Fibre broadband connection password?
- Re: Fibre broadband connection password?
31-03-2013 10:40 AM
How do I find out what is my Fibre broadband connection password?
I like to setup pfsense router and I need to connect it BT Openreach modem.
username would be like this: username@plusdsl.net
but what the password would be?
Message 1 of 5
(1,953 Views)
4 REPLIES 4
31-03-2013 10:48 AM
It's the password you use to get in the members centre one you made up
Message 2 of 5
(894 Views)
31-03-2013 10:55 AM
Ahhhh I see, thanks!
Last question,
On the Technicolor 582n - how to disable NAT and DHCP? I would like to set that as Access Point for wifi only.
From my understanding on pfsense:
WAN (Eth0) <-> BT Hub (Open Reach Modem)
LAN (Eth1) <-> Switch <-> Technicolor 582n (Use it for wifi)
dick:quote
Last question,
dick:quote
Message 3 of 5
(894 Views)
31-03-2013 11:12 AM
Quote On the Technicolor 582n - how to disable NAT and DHCP? I would like to set that as Access Point for wifi only.
Log into router, select Home Network, click Interfaces then Local Network and Configure.
untick Use DHCP Server and click Apply.
You might also find it useful to Allocate the TG582 a static IP on your pfsense local subnet ( not needed unless you need to access it GUI when connected )
Connect port 1,2 or 3 ( not 4 ) of the TG582 to the switch.
The Tg582 should now act as a wireless AP
Message 4 of 5
(894 Views)
03-04-2013 9:57 AM
Message 5 of 5
(894 Views)
